NEED TO KNOW ASAP
Old Nov 20, 2009 | 10:13 PM
VQphantom's Avatar
NEED TO KNOW ASAP
What is the voltage suppose to be for the 3.0 de injectors
Old Nov 20, 2009 | 10:48 PM
DennisMik's Avatar
When the car is running, the fuel injectors have 12 volts supplied to them through the ignition stitch, red wire. The ECU then grounds the other wire so that the electromagnetic coil energizes to let gas flow. If you are using a volt meter, you may never see the other wire (not the red) go to 0 volts as the time is so short.
If you are having a problem with a cylinder not firing, check the resistance of the coil in the fuel injector. I think it should be about 12 ohms. Check all the injector coils and if one is way off, its bad.
Also, if you are having a problem with a cylinder not firing, make sure the coil pack is creating a spark.
Old Nov 20, 2009 | 11:05 PM
VQphantom's Avatar
Ok thanks and i got this code too
Code: P1320 | Description: Ignition Signal[/url]
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
