some tuning and means to read info ? , Nmex you out there
Ok so i have been reading posts for the last month if not since i got the max 5 years ago on everything from upgrading to headers, BBMAF, piggyback systems and mean to read all the info with a WBo2. So now im getting more confident in taking the plunge on electronic upgrades.
my ?s are basically on how to read and tune the data so it makes the car happy.
Ill make my questions short.
1. i will be installing a BBMAF (3" id) when its get nicer out. i was reading Nmex's post and he suggests the SAFC2. So once i get the cash ill pick that up. Should i get the SAFC2 over the SAFC VAFC or VAFC2?
2. i know i need a WBo2 but i dont know which one is good, as well as what i should expect to pay. Can i just get a sensor and gauge so i can read whats happening to the AFR.
my engine mods are CAI..with BBMAF to follow after winter, vias block plate (up high feels like a nitrous shot), test pipe and flowmaster muffler. i know not a lot but once i get the BBmAF and tune i think ill be happy till i get cash for headers.
thanks for all the replies and NMEX, 6spd, or SR20 ive read all your informative posts just looking for some answers from the horses mouth so to speak
VAFC2 has more tuning points so it allows you to have a finer fuel curve. Get one of those.
And really? Have you been to the All Motor Forum. This is stickied http://forums.maxima.org/all-motor/5...ther-info.html
Anyways, some quick searching on eBay shows that a wideband O2 sensor with the gauge goes for about $200 new. (Innovate LC-1). I'm sure you can find a used one somewhere as well.
no my bad i didnt go to the all motor area. seemswhen i look at the uego, or lm1 or plx or whatever they look around 350 or so. i get the more tuning points but from the posts ive read regarding a bbmaf the consensus was a safc2 over the vafc2
General consensus?
VAFC2 has the same ability to change the sensor configurations for BBMAFing. Page 46 of the installation manual.
http://www.scribd.com/doc/12609713/Apexi-vAfc-II-Manual
moncef, yea i went to the all motor after you told me to go there and see nmex just posted a few minutes earlier on a thread. ok so a vafc2 it is as i know it has more tuning points. and ill look into the aem uego. i think i might wait til feb or march to install this stuff once i get it. it is single digits right now with 40mph wind and i dont feel like getting frostbite hahah.
with the aem, can you connect a laptop to it in the car and record a run so you are able to adjust fuel. i think i read somewhere it records, this is datalogging right?
Datalogging = recording a run and making adjustments according to the data pulled from that run.
AEM UEGO is what I have. And I cannot datalog to a laptop, I've got my wideband hooked up to my e-Manage Ultimate which logs every engine parameter including air fuel ratio.
If you're gonna buy an AFC and wideband you'll need to get a Zeitronix ZT-2 or Innovate LC-1/LM-1 which have USB interfaces to talk to your laptop, since your AFC will not hook up to a laptop.
I actually just started to tune my car myself.
I bought the Innovate LC-1 wideband for $190 off ebay. It comes with an LED gauge and all the hardware required for the install.
Also have to remember that the LC-1 connects to the computer by means of a serial port, so if you don't have a serial port on your laptop, you'll need a USB to serial adapter.
And I have a VAFC II because it has more tuning points, as mentioned above.
I recommend the zeitronix wideband, mostly because it comes with software, datalogging and it tells you what your afr is at whatever rpm's you are at without any extras. I think it is the best value for the buck. It graphs out your afr vs rpm for every run you make.
for the lc-1 is this what i would need... anything extra other than a cord to connect to the laptop?
http://cgi.ebay.com/INNOVATE-LC-1-Wi...item56386069f0
or this?
http://cgi.ebay.com/ebaymotors/Innov...Q5fAccessories
or this?
Does the e-Manage Blue have a built in datalogger that you can connect your Wideband to?
Weak
kidding
I didn't think you could get RPM cable for the LC1, the only P/N I can find for an RPM cable is the LMA-2 which is for the LM-1 wideband.
Which is why I mentioned the AuxBox, because it can pick up a tach signal and log it (LMA-3)
kidding
^^^^^^^You're right...I hate you.. I found the F/S thread.
http://forums.maxima.org/general-max...converter.html
hahah maybe ill do that. keep the cost down and still be able to tune ... although thatway may take a bit longer to do hahaha
actually i have a question on all this stuff. as you can see what my current setup is... i have the 3" bbmaf but just not installed obviously. after getting the vafc and a af wideband will it gain noticeable powerand be a worthwhile investment. what i mean is after spending for the vafc and wideband if it is only going to add 5hp since i dont have headers (and prob wont for a long timeor ever) i may not do it. if it can make a pretty good diff then it would be worthwhile. what do you think?
BBMAF is mostly for throttle response and to help the engine breathe better. That usually means more horsepower. And the search function sucks **** right now so I don't think you will find much info.
Also, if your end up installing the BBMAF, you may want to mess around with the narrow throttle map feature on the VAFC II.
You can adjust for anything below 39%, this way you can get your long term fuel trims as close to 0 as possible.
well i know im gonna get crap for this but i just wanted to see what would happen. i have my bbmaf all set and ready to install. so yesterday i put it on like this TB>3" id 6 " long int pipe w pcv hose>bbmaf> 2.75"id 22* pipe> bbk oval air filter. well on the first 2 start ups it ran like my 68 camaro on a winter day.. gasping for air (or fuel), sputtering so i shut it down. Tried again and it idled fine. so i took it down the street 1/2 mile and all i can say is glad i didnt get stranded. giving it gas the engine hesitated and bogged and just didnt do good. needless to say i went back to what i had. now i read in the post with rodriguez when he put the BBMAF on with no tune and his ran fine but i think he already had a vafc or safc installed so maybe that had something to do with it. so yea when your told you need a tune along with it thats the truth.
Moncef ive read all the BBMAF threads, headers threads, vafc, safc and so on.. ive been researching for god knows how long now. all the info gets overwhelming and then you get one answer that conflicts with a different answer. i just wanted to get some fresh takes on the subject
I have not installed it permanently yet. I did install for a test but I did not go for a drive. I know it will be starving for fuel. But at idle (closed loop) the ECU will learn to compensate so I was not too worried. I think it would be safe to drive the car under 2k rpms with no ill effects but the AFR would be way off above that.
The only reason I have not installed this yet is because I was laid off from work for about 5 months last year. I lost about 50 K or more in wages. I can't afford a dyno tune at 160/hr right now. Yes it's expensive up here, we don't have a lot of places we can go. But the guy I go to knows his stuff so paying a little more gives me peace of mind that my car won't fry.
My setup is an 80mm tube approximately 17" long with a velocity stack. I have high hopes for it along with the spacers and block off plate. Hoping to get minimum 260 at the wheels after a good tune. I also snagged a set of g35 injectors (20cc bigger) For 40 bucks so they have to be installed as well.
I need to find someone who can sit down with me and show me how to use the e-manage software to tune my car. I just have no clue how to navigate all the menu's. I'm hoping in the spring that my dyno guy will keep his word and show me how to go through everything so I can street tune.
Here's a video...
http://www.youtube.com/watch?v=P90VnjMh5EQ
Definitely needs a tune, sounds nice but there is some hesitation at midrange, but I think my MAF may be on the way out as well as I get some hesitation with my present setup.
Here's a video...
yea like knight said after a few tries it did compensate. pulled out of the driveway fine but when giving light throttle it started acting up. so i said nope dont kill the engine and wait for atune.
rroderiques, i thought you made 12 hp gain. that seems pretty worth it. did something change?
sdotcarter
Sep 2, 2015 09:53 PM
