P0303 Code (Cyl. 3 Misfire)
Old Jan 12, 2010 | 03:53 PM
stas29's Avatar
I just got a P0303 code on my 2002 I35 with 113k miles. The code description states that it's a "No. 3 cylinder misfire detected" making my engine run a little rough. So I assume I must have a bad ignition coil on cylinder 3 which is located in the middle all the way where the firewall is. Do I need to remove the entire intake manifold to get to it or can I just remove that metal intake piece that connects to it from the back? On my 1997 maxima it was fairly easy to get to ALL of the coils. On the Ebay coils are fairly inexpensive @ 33.20 shipped to your house via priority mail.
Thanks guys.
Old Jan 12, 2010 | 04:20 PM
wyche89's Avatar
the middle one (of course) is the only one you can't get to without taking the intake manifold off.. have you considered that it could be the injector or the spark plug?
Old Jan 12, 2010 | 04:29 PM
stas29's Avatar
I read somewhere on the forum that injectors usually do not go bad. I always put Shell Premium gas so hopefully it's not an injector. Tomorrow I'll just remove the intake manifold and troubleshoot #3 injector, spark plug and an ignition coil. Is it safe to drive the car with a misfiring cylinder?
Old Jan 13, 2010 | 08:03 AM
sontakke's Avatar
If you have flashing check engine light, then it is bad to drive like that. If you have rough idle and/or sever loss of power, then it is bad to drive. If you get occasional rough idle and steady CEL, then it is OK to drive for a while.
- Vikas
Old Jan 13, 2010 | 08:11 AM
Rochester's Avatar
If you're spraying gas without burning it, aren't you putting your catalytic converter at risk for damage by overheating as the gas works its way through to the exhaust?
And wyche89, it's just the upper IM that needs removal for access, right? A confident DIY, or an easy job for a mechanic.
Old Jan 13, 2010 | 08:26 AM
stas29's Avatar
It looks like, at least to me, that I just have to remove the metal piece that goes into the intake manifold upper collector to gain access to coil #3 and not the entire plenum, hopefully.
Old Jan 13, 2010 | 09:11 AM
stas29's Avatar
Thanks for a reply! My engine light is blinking. I also have a 97 nissan maxima which i been trying to sell for like 2 months now but i can not drive it because i transferred license plate to infinity. I guess i'll have to drive my friend's old ford fiesta which is completely covered with bumper sticker until i get it fixed. It's like 40 degrees outside so kind sucks to work on the car.
- Vikas
Old Jan 13, 2010 | 09:43 AM
2slow's Avatar
If you haven't already, you may want to take the opportunity to also replace the rear valve cover.
Old Jan 13, 2010 | 11:10 AM
SuperStasiu's Avatar
that would be a good thing to take a look at but you may also want to replace all the coils and new spark plugs while your at it since the coils could continue to fail on you kind of like a domino effect, just some insurance for later on
Old Jan 13, 2010 | 01:08 PM
rroderiques77's Avatar
Demodded and Forgotten
Things you should replace while you're back there (assuming they haven't been done yet),
-plugs (all 6)
-rear valve cover with updated model
- IMO, I would replace all three rear coils
Old Jan 13, 2010 | 01:37 PM
Rochester's Avatar
-plugs (all 6)
Replacing just the rear packs is a good idea, since coil packs are expensive and the fronts are always accessible.
"Domino effect", SuperStasiu? Really? Hmm, I blew #6 two years ago, and #4 last year. Not really interested in spending the bucks for the remaining four, but it has crossed my mind on more than one occasion.
Old Jan 13, 2010 | 07:26 PM
I did that on my 01 to save myself trouble later
Old Jan 14, 2010 | 06:56 AM
sontakke's Avatar
Is the valve cover gasket necessary for 2000-2001 model? I believe for coil/spark replacement on the rear bank, the valve cover does not come off.
- Vikas
Old Jan 14, 2010 | 07:41 AM
stas29's Avatar
- Vikas
You have 3.0 engine so it is fairly easy to access to access to rear coils and spark plugs. Maximas leak oil from valve cover gaskets after about 70,000 miles, so it's a good idea to replace them unless you prefer seeing smoke coming from underneath the hood. The front and rear valve cover gaskets are only $20 at autozone so u may as well get both of them. Be VERY careful when you try to pry off the valve cover as you do do not want to scratch the surface of the engine.
Old Jan 19, 2010 | 08:56 AM
914Max914's Avatar
i got the same code i went in there switched the spark plugs and tightened them all and it went away? i think my plugs were loose..
Old Jan 20, 2010 | 09:27 PM
joeltender's Avatar
I changed #3 coil only and valve cover (04 of course) over a year ago @108K, no problems since @120+
Old Mar 25, 2011 | 08:04 PM
Scottwax's Avatar
That's Mr. Detail to you
Hate to bump an old thread, but I just got a P0303 tonight and it was making the SES light flash if I didn't baby it. Definitely can feel a misfire. Can I just take the elbow off the intake or do I have to remove the whole thing to get to the #3 cylinder? I do have a set of coils I bought off another .org member so I might change all three while I am at it.
Old Mar 26, 2011 | 02:18 PM
Eirik's Avatar
Good luck with the oil-burning, but bad luck with the coilpacks, eh? =/
It doesn't take much labor to get the intake manifold off. Heck, you can just take all the bolts off and have somebody lift it up while you tinker away at your bad coil. That's what I did when I changed the plugs.
Old Mar 26, 2011 | 03:15 PM
Scottwax's Avatar
Figured it out...
http://forums.maxima.org/5th-generat...isnt-hard.html
Old Nov 26, 2011 | 11:37 PM
swtsnstn124's Avatar
Hey did you ever fix your problem if so what did you do, mines is throwing the same code and running really rough.
Old Nov 27, 2011 | 10:21 AM
bocian's Avatar
Yea and im curious about the ebay coils, ice nothing but bad things about cheap ebay coils, im all for saving money but with these cheapo coils, it seems like youre going to end up spending a lot more in the near future
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
