245/45/18 with coilovers
Old Jan 26, 2010 | 08:37 PM
10psigti's Avatar
i wanted to know if 245 45 18 tires will rub on a 4th gen with coilovers lowered about 2 inches all around
Old Jan 27, 2010 | 02:43 AM
MAX/GTR's Avatar
I'm running 245/45/18s on my max. I've got them on SE-Rs no problems with rubbing, I had to take the splash guards off though to clear them for hard turns. It ribs a little bit when I make a super hard u turn to the left but that's it. Other than that I never bottom out or scrape or anything like that. Even on really hard drops, drive ways and speed bumps. So you should be fine
Old Jan 27, 2010 | 06:04 AM
cashoit's Avatar
I did some research and learned what coilovers are. But our car doesnt use them stock. Why put them on? And why do u need them if u are doin a OOVI swap?
Anybody?
Old Jan 27, 2010 | 06:33 AM
Nealoc187's Avatar
SLOW
Anybody?
What are you talking about? What the heck do coilovers have to do with an 00vi?
Why put them on? Some people want to be able to adjust the ride height of their car, or have stiffer springs than any of the regular spring offerings.
Anyways, that combo would result in rubbing when turning the wheel all the way to lock, and possibly some slight rubbing on the fenders under really hard cornering like you'd see on a track, if you're in to that.
Old Jan 27, 2010 | 02:44 PM
Snypa's Avatar
245/40/18 rubbed in the rear for me until fenders were rolled. Will rub in front on u-turns.
Old Jan 27, 2010 | 07:41 PM
10psigti's Avatar
thanks for the reply what suspension are u running
Old Jan 27, 2010 | 08:07 PM
tunafish51's Avatar
Anybody?
LOL wow you're reallyyyyy new
Old Jan 27, 2010 | 08:21 PM
MAX/GTR's Avatar
No prob, I know what's it like to have a question and olnit be able to get a legit answer. But you don't have to run an 00Vi to have coilovers or vice versa. The 00vi is basically ur intake manifold system swapped from a DE-k motor from a 2000-2001 motor. Coilovers are supension and replace your struts. They work independently of one another so it's driver prefernce to use them or not. I was running tein super streets but that was on an older max. Runing stock struts now. Hope that helps bro
Old Jan 27, 2010 | 10:59 PM
wirelessdude04's Avatar
Yea 245 45 18 you will rub making hard u turns
Old Jan 27, 2010 | 11:31 PM
NismoVQdet?'s Avatar
what offset are your rims? thats what matters the most. had a set of +35 and they never rubbed with the same tires you want. +30 on the other hand always rubbed when it bounces around.. oh i'm lowered 2.2
Old Jan 28, 2010 | 01:36 AM
10psigti's Avatar
altima ser rims dont know offset
Old Jan 28, 2010 | 02:23 AM
saylee's Avatar
bro, have you consider taking it down a notch?? im rollin on 225/45/18 and they are perfect, no rubs or nothin... im dropped pretty good too.. maybe if you took it down to 225, youll be set and ready to roll with no rubbin... I rubbed in my bmw but i rolled the fenders so no more rubbing problem...whenever i drove and hit a bump i used to feel and hear rub but i switched to 600lb springs and it was good after that..
Old Jan 28, 2010 | 03:09 PM
10psigti's Avatar
rolling the fenders is no problem its just that i live in nyc and the potholes here are serious so i wanna keep the stock profile tire for the extra meat ive also got 225 40 18 tires but ride too rough
Old Jan 28, 2010 | 04:59 PM
LLZuB's Avatar
245/45/18 rubbed in the back for me aswell on the fender, but it could be because my rear axle is out of line a bit lol
Old Jan 28, 2010 | 05:13 PM
Crusher103's Avatar
keyword is offset. what is urs?
i have had 245s on a +40 offset no rubbing, put them on a 30 offset wheel and i get rubbing.
Old Jan 28, 2010 | 05:14 PM
LLZuB's Avatar
very true, I was running 350z rims, can't remember offset on those
Old Jan 28, 2010 | 08:50 PM
10psigti's Avatar
offset is +45
Old Jan 28, 2010 | 09:31 PM
Conrad283's Avatar
I need a truck
I was running 245/35/18 (I think, I don't quite remember though) with H&R's (~1.3) without any rubbing.
Old Jan 28, 2010 | 10:41 PM
ImmaSquashYou's Avatar
225/40/18 tires will bend your rims. I know for a fact cause i ran smaller tires for a while cause they came with the rims. I was from central jersey and know how bad pot holes can be in jersey and in ny. You need at least 235/40/18 otherwise once you hit a pothole, your rim is gonna be bent. If you want to save your rim more, i would go with a 225/45/18
Old Jan 29, 2010 | 07:23 AM
Crusher103's Avatar
offset is +45
u wont rub the fender, it will probably clear the suspension aswell. u shouldnt have any issues.
Old Feb 7, 2010 | 02:30 AM
10psigti's Avatar
thanks thats what i was thinking
this is not true i had 225 40 18 for over a year and hangout in midtown manhattan all the time and you know how ****ed up the roads are there and never bent a rim its all in how you drive
Old Feb 7, 2010 | 11:04 AM
ivorton23's Avatar
you should just put some 17 inch rims n tires on it and save the headache. i plan to get ksport lowering springs 2.2' frt n 2' rear and put these rims on my 96 max.
Old Feb 7, 2010 | 11:54 AM
Crusher103's Avatar
no.
Old Feb 7, 2010 | 12:14 PM
maXspeed96se's Avatar
i had 350z wheels on my car with D2s and about 2.75-3in drop with 245/45/18 and it rubbed on every bump i hit
Old Feb 7, 2010 | 01:23 PM
B_Eaze's Avatar
235/40/18 is what I'd go with but thats just me
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
