clutch masters stage 4 + aluminum flywheel install pics
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Started the install Saturday morning and spent around 8 hours total on it without any rush or complications. Overall this was a lot easier than most people make it out to be, but getting the transmission in/out is rough.
I didn't take many pics...
Car lifted and ready to begin early Sat. morning.
Pic of my exhaust while it's up. Notice cattman gave me 1 mild steel flange on my Y-pipe, lol!
Work area with everything dismantled and the transmission out.
Bare metal on the stock clutch disk
It was great having the car that high for getting the transmission in/out, although standing on a stool to work under the hood was a little tough at times.
If I launch under 1k rpms, it will shutter a tiny bit. Otherwise, it's just a fast engagement (can still slip it fine) right off the floor.
stage 4? no ****?, curious of what your times are before this install, also I hope you don't do much city driving because I heard going over a stage 2 kills your leg!. awesome install and great looking car man. good luck in whatever you have instore in the future.
Thanks for the info on the clutch! Let us know how it is when you are in traffic though, probably gonna suck.
The pedal effort is actually FAR less than stock from the top down to about 1" from the floor which is where the clutch engages/disengages. From that point to the floor, it's about 50% more effort than the stock pedal but still easy and comfortable.
This is a very welcome change from the mushy stock pedal that had no obvious engagement point which also happened to be about mid-throw on the pedal, which was very bad for fast shifting and annoying for launching. Everybody who has sat in my car and operated the clutch pedal says "wow you can tell exactly where it engages!"
Also, the ceramic material requires nearly no break in and can take massive abuse. Slipping a ceramic clutch does not alter it's performance. Were I to slip one of the Kevlar options too much, it could overheat and NEVER recover... slipping for the rest of its life.
In terms of city driving, I've done about 100 miles so far of almost pure city driving and have gotten completely used to the clutch. I stalled it 2-3 times on my first drive due to it engaging RIGHT off the floor, which is awesome but took some getting used to.
My leg actually gets less workout in traffic than with the stock clutch, because with this clutch I can keep my foot towards the bottom of the clutch pedal's throw, and just engage/disengage the clutch with minimal foot movement.
I did one hard WOT shift 2-3 earlier day... wow, it resulted in tire chirp which is very uncommon for my grippy street tires. With the stock clutch, I rarely even chirped into 2nd gear. It INSTANTLY grabs. You can see in the videos that I made with my old clutch that it slips away for a bit before engaging all the way on each gear shift, which I'm sure killed MPH and a little ET at the track.
My last best run on the day that I believe was the "last straw" for my stock clutch was the 13.01@106 N/A. On that run, the clutch was slipping on hard shifts and I banged the rev limiter in first. Therefore I am fairly certain that on a similar weather day, I have potential for some 12s.
I probably also now have 1.7 '60 foots with this clutch, but I am very worried for my axles so I will be babying the launches a bit to try and find the least jarring way to still pull a fast '60 foot.
Cattman talked me into it after a long conversation and I'm glad he did. I was initially considering a stage 2 or 3.
Launching on street tires is going to be an all new beast the way this thing grabs. With the stock one going out, I could just let it out hard and it would slip me to a smooth launch, like shown in this video
Clicking Sound
I am getting a clicking sound in the first 3 gears, then after I shift to gear 4 I don't hear it anymore. It is a original OEM transmission and clutch with about 160000 miles on it. I also I have a Timing chain on it, can you help me with that.
When I have an important question, I ask the wizard.
Just wanted to bump this for a nearly 1-year review.
Pedal effort is still similar to stock until you're getting close to the engagement point, then ramps up. I have no issues in traffic or long trips with my leg tiring out.
Chatter/shudder can be a pain if you're trying to slip it from low rpms. Slipping too much or from below around 2000 rpms can result in the whole car shaking. Generally this isn't a problem, you just relearn how to drive it. Others in traffic around me probably think I'm a ricer launching from 1500-2k rpms to ensure a smooth start.
It grips like no other. Could have been part of why my transmission finally gave out a few months later after some hard track time.
I haven't gotten new 1/4 mile track times yet, but 1/8th mile times have shown improvements of .15-.2 and 1.5-2 mph from the 13.0 ET and 107.5 trap without any other major mod changes (still vias delete manifold, sold the kinetix before it was track tested).
vingodine
45
May 21, 2016 12:46 PM
