FS: Foglights with Yellow Capsule Mod
97'-99' Foglights with yellow capsule mod - $60 shipped
Here is a fun one for you. I modded a pair of foglights using the Lexus yellow capsules per the tutorial on this board. I hooked them up, they both worked beautifully as they were supposed to, and the yellow effect is very bright, very noticeable, and very nice.
The driver's side light is still in great condition and the mod is still intact/functional. Some water got into the passenger side light where my seal job was weak and rusted the bulb fixture to a degree, so there is rust on some of the metal and some rust residue on the glass as you can see in the picture. Also, the yellow capsule has come loose from where I JB-weld'd it on.
As I said, the driver's side one is a perfect example of the of the successful mod, and the foglight itself is in good shape. The passenger one has some cosmetic rust inside, which you can probably scrape off and wipe off the glass, since you will have to open it up to reattach the yellow capsule anyway. BOTH lights still work (the wiring/bulb socket is not damaged). Even if you don't want to repair the mod, this is a good buy just for the brackets (and screws, which aren't pictured), the glass faces (no chips), the wiring and fixtures, or you can remove the capsules and do something else with them. Opening the light to fix it is easy, especially once the intial seal is already broken. Let me know if you have any questions.
