Cylinder Misfire
Cylinder Misfire
A friend of mine believes that he might have a cylinder misfire. He was wondering what he should do to rectify this problem. He has a 1996 SE, manual transmission, 80K, and has been putting in 87 octane
in his tank. He became aware of the problem when he took his car to replace a knock sensor. The mechanic told him there was a cylinder misfire but was unable to tell him which cylinder it was. I wasn't sure what to tell him so I thought I'd ask the org.
GhettoMaximaz
in his tank. He became aware of the problem when he took his car to replace a knock sensor. The mechanic told him there was a cylinder misfire but was unable to tell him which cylinder it was. I wasn't sure what to tell him so I thought I'd ask the org.GhettoMaximaz
Re: Re: Cylinder Misfire
Originally posted by jran76
If there is a misfire, the check engine light should be on. If you run the code it should tell you which cylinder....
my brother has a 99 SE-L and just had the coil replaced for a flashing check engine light... but he was getting a code in the ECU also... Funny part is that they first replaced an injector and moved the coils around... the problem followed the coil on which the code was coming from and then they replaced the coil...all is good now.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
