2000 nissan maxima speed sensor location?
Old Apr 6, 2010 | 11:58 AM
Eg2707's Avatar
Hello everyone, I've been trying to find the location of the speed sensor. my speedometer doesnt work and its throwing a check engine code (speed sensor). I searched for hours on google and even on the forums. no luck.
The only part I could find on the car is the revolution sensor which looks like this
http://picasaweb.google.com/cefiro.calsonic/P0720VSS#
I am trying to find the location of this speed sensor
http://info.rockauto.com/getimage/ge...tex/5S4938.jpg
its really been driving me nuts. I have searched all over the tranny top/ and /bottom/side . I really feel like Im searching for an invisible part. can anyone please help me out. pictures or detailed directions to get to the part would be greatly appreciated
Old Apr 6, 2010 | 12:12 PM
Love_00_Max's Avatar
The speed sensor is the ABS sensor. The revolution sensor is on the tranny, now which feeds the dash is anyone's guess. If you take off the tire you will see the the revolution sensor, it is very obvious. U cannot miss it!!!
Old Apr 6, 2010 | 12:20 PM
Eg2707's Avatar
I thought the 2000 maxima was the last to get the speed reading thru the tranny. i read on the forums that the 01+ get it thru the abs speed sensors? i may be wrong can any one clarify this?
Old Apr 6, 2010 | 12:21 PM
CraigSE's Avatar
VSS is gonna be on the trans somewhere. On most cars seems to be at the back near the firewall. I don't know this car well enough yet, and I haven't seen mine, but I can't see how it could be anywhere else.
Eg2707's Avatar
oh btw i know where the revolution sensor is haha its the only one i can find =(
Old Apr 6, 2010 | 12:37 PM
The speed sensor is on the bottom of the steering knuckle.
There are 2 sets of tubing from engine bay to the wheels, one is the brake fluid line and the other is the wiring to the speed sensor on the steering knuckle!!!
Old Apr 6, 2010 | 12:48 PM
Eg2707's Avatar
im not looking for the abs speed sensor on the wheel..im looking for the gear looking speed sensor in the 2nd link i posted. I went to the dealer yesterday..they said thats the 1st part to check
Old Apr 6, 2010 | 01:11 PM
CraigSE's Avatar
Is this car manual or auto trans?
Old Apr 6, 2010 | 05:41 PM
Eg2707's Avatar
it is automatic
Old Apr 6, 2010 | 06:01 PM
CraigSE's Avatar
Judging by the pic in the FSM it looks like the VSS is on top of the trans. Not too far from the starter.
Old Apr 6, 2010 | 09:10 PM
dewd's Avatar
tps ? throttle position sensor or something no ? with the 2 connectors ?
actually. check this out. http://www.buzzle.com/articles/sympt...on-sensor.html
Old Apr 7, 2010 | 02:06 AM
Eg2707's Avatar
well i found the vss. but im looking for the speed sensor in the 2nd pic..the gear type looking part
Old Apr 7, 2010 | 02:07 AM
Eg2707's Avatar
not looking for the tps..looking for the speed sensor pic on the 2nd link
Old Apr 8, 2010 | 08:38 AM
aleem's Avatar
above the passanger side axel on the tranny. i can provide a picture lmk. i just change my tranny and the one i bought had a cover on it and mine had a sensor
Old Apr 8, 2010 | 08:43 AM
aleem's Avatar
Old Apr 20, 2010 | 06:06 PM
Eg2707's Avatar
so was the sensor the gear looking part?
Old Aug 30, 2010 | 05:16 PM
Eg2707's Avatar
Ok got some new news. the car was diagnosed by a auto repair shop. since my sister got the $500 state assistance on failed smog,
The shop noticed the ABS light bulb was burned out and replace that.
The year and model maxima I have does not have a speed sensor on the tranny. and gets the speed through 4 abs wheel sensors. they are thinking the abs control module is bad and recommended that. Since the car has four sensors, is it possible for one faulty one to cause the spedometer not to work? the check engine light also throws a speed sensor code. So would they be correct on a faulty abs control module? any further help would be greatly appreciated thanks
Old Sep 18, 2010 | 08:53 PM
mikevee's Avatar
Eg 2707 my 2001 maxima se doesn't have a speed sensor either, at least my dealer said it didn't. My transmission has a cover over the hole where the speed sensor would go. My speedo only goes to 25 mph and i have an abs light on. Are they related? Any help appreciated.
Old Jun 30, 2011 | 04:10 PM
lil.kick's Avatar
one of my speed sensors needs replacing..speedo works after driving round town it doesnt pick up speed and rpm gauge goes all the way up when i press the gas..wut is goin on 2000 max se
Old Jul 16, 2011 | 02:57 PM
cwoodside1's Avatar
I have a 2001 maxima SE and I just replaced the output speed sensor. Part 917-611. They told me at Auto Zone this was the part needed. The trans was dropping out of gear like everyone is talking about on this thread. I was pretty happy it was so easy and thought for sure it would fix my problem. But no..... I drove it for a while today and it started doing the same thing.... Is there another sensor anywhere? I am seeing some posts that talk about two sensors... Any help appreciated
Old Sep 18, 2011 | 12:29 PM
oneoldhoosier's Avatar
I m a new member all this dribble is of no help at all AAP shws 2 VSS 1 gear driven and 1 is "magic / electronic " If I could fine the one on my 00 AT I would take it out and buy one that looks the same...Need to know where the darn this is......JC
Old Sep 19, 2011 | 05:04 PM
eddie8890's Avatar
nice pix my friend need to change tooo thxxxxx
Old Mar 5, 2013 | 05:41 PM
Captain Redneck's Avatar
worked for me...
I found the "Transmission speed sensor" behind the front drivers side tire on the transmission. quick 10 minute change but $135.00 part. I deliver pizza's in my maxima. From a stop sign it would take off ok but then either (A) leave first but not engage second gears and only re-engage first if I hit the gas. or (B) shift erratically around 35 mph and then go into the not engaging second gear thing again. The "speed sensor" in behind the Passenger side tire on the steering knuckle or "brake caliper mounting position?" behind the brake caliper. also this link might help as well. http://forums.nicoclub.com/strange-t...g-t349433.html
Old Mar 5, 2013 | 06:18 PM
shaks's Avatar
good thing you bumped almost a 2 year old thread! check the date of the last post in the future!
Old Mar 5, 2013 | 07:51 PM
jomurill's Avatar
here is a good one!!!
Old Apr 23, 2013 | 08:55 PM
Parker Corynn's Avatar
Engine speed sensors, which are not to be confused with a vehicle speed sensor, are sensors that are attached to the crankshaft of a car's engine.
Old May 8, 2013 | 01:07 AM
yarddell's Avatar
01 max
I have an 01 max automatic which has atleast three sensors relating to speed. There is one right behind the left front tire, one near the fire wall, and one other on the transmission.
Old Aug 27, 2013 | 01:16 PM
Reamo13's Avatar
So how many speed sensors are there and where are they?..if you can help me
Old Oct 24, 2013 | 06:59 PM
nestorlugo's Avatar
Size:  101.7 KB for further assistance on the other sensors you can see it top left of the axle..mounted on the tranny by the 10mm bolt
Old May 13, 2014 | 02:13 AM
MaximusRojas's Avatar
location location
There are two speed sensors on the tranny...i got the same issue. The first sensor is on top of the tranny by the transaxle. To get tobit u have to remove the entire air intake n it sits directly under the intake. The other speed sensor is right behind the driver wheel, this semsor is called the "revolution sensor" remove the drivers wheel n remove the wheel wall and there it is
Old May 22, 2014 | 02:24 PM
Rcrootbeer's Avatar
Was this issue figured out? I'm dealing with the same symptoms.
Old Oct 11, 2014 | 07:52 PM
jdplanas's Avatar
why
is this issue resolved?i am having this problems too. i have a 2000 maxima se automatic and have changed the pinion sensor and revolution sensors and also tightened some back screws on the dashboard... still having p0500 code linking to speed sensor. im thinking of troubleshooting the wiring harness. any inputs and or diagram how to?
Old Jun 7, 2015 | 02:11 AM
andreyd234's Avatar
Hello, I'm new here.
Same problem, been researching it quite a while, here what I found in wiki:
"...This generation of Maxima also saw Nissan introduce a Bridgestone-made engine mount with sensors that communicate with the ECM. Many transmission-like problems such as 'unable to shift into higher gears' resulted from worn engine mounts triggering signals to prevent the vehicle gaining higher speed. This problem was not often detected by the diagnostics conducted on the transmission and ECM as they were not the cause of the problem."
http://en.wikipedia.org/wiki/Nissan_...2.80.932003.29
Looks like it might be a problem after all, will try it and post on my findings. Also I order VSS sensor of ebay for 17$, just in case, My Maxima have over 190000 and everything stock, only new starter 2 years ago.
Old Jun 3, 2017 | 12:02 PM
uptowndrizzy's Avatar
code p0500 help
hey guys I got a 2000 max with the p0500 code and I know where it is but when I went to replace it and its just like a plug or cover no sensor no harness is it anything I can do thanks in advance
Old Dec 11, 2017 | 05:46 AM
dave daughtrey's Avatar
2000 maxima speed sensor
Did you find your speed sensor, mine has a plug also where the VSS sensor is and I replaced the pulse sensor on the tranny but still get the P0500 Speed sensor A code
mrc00l88
Jan 25, 2024 01:14 PM
09maxshawn11
Aug 14, 2015 10:07 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
