Installing amp and sub without changing the radio- using a spliced RCA wire
Check out the link below. It is from a Mazda forum. They basically use a single male to double female RCA wire... splice it and wire it up to the stock 8" sub on the rear deck of a Mazda 6.
Can't we do something similar like this with our Maxima's as well?
I did it on my Mazda 6 and it worked perfectly. Sound quality was fine. I actually still have that spliced RCA wire and was wondering if anyone knows which wires I could possibly connect it to on a 04 Maxima.
Here is the link with pics (scroll down for splicing part)
http://www.mazdas247.com/forum/showt...hp?t=123698578
read here, post 15 http://forums.maxima.org/6th-generat...subwoofer.html
I use a line out converter sounds fine but that was before I got the ipod NIS module and noticed the factory line out converter.When I have extra time I will probably pop that thing in there just cause it is a lot cleaner of a install.I think its worth the money.
lol Of course after market subs with after market amp will push more bass. That putrid bose system pushes out about 250 watts max? I even doubt that as the amp is so damn small. I used to run two 12s myself but now going to run single 12 on Kenwood true 600 watt amp. I just misunderstood what he was trying to say!
Even so I would cut out the stock sub as the aftermarket sub will over power the bass over the stock anyways!
I’m running a Small Aftermarket amp with a 10” Kicker Sub.
Using the “Splice” RCA’s Hookup & Factory Power Wire & New Ground Wire….
Works Just Fine….. For About 1-Year Now.....
Changed the Factory amp and Sub because it kept Cutting Out.
NOW when I roll down the windows I can still here the Bass….
Nothing Spectacular ((But it gets the JOB Dun))….
I Can Provide a Picture of the Spliced RCA if Needed!!!!
Sounds like it's a good set up. I am getting rid of the bose set up myself. I have an Alpine CDA 7995, but since it doesn't have an internal amp I am going to use JL E4300 4ch. For the sub, I have Alpine Type R 1422D 12" ran by Kenwood Excelon KAC X-201T. Should sound decent! I really can't stand Bose but it is doing alright for now.....
stock bose 8 speaker (2- 8"s in rear deck)
plus 10" Arc by Foose in a Q-Logic bandpass driven by a pioneer. dont remember which one, but is 800 max.
already had the box. and have it setup against my driver backseat so i can fit my snowboard and gear. firing up and ports facing the rear. amp is mounted to the box for quick removal.
i know there's way better options, but for me to spend the money and replace a system i'm happy with for 6 years makes no sense to me. don't want any more bass, highs are plenty. Mostly use Sirius. rarely CDs, which are almost as good quality. otherwise my ipod on rare occasion, which is a lower quality since compressed anyway.
edit for wiring.
simply ran power to the battery. otherwise, ground is under the rear seat. remote is spliced to bose oem rear amp, and line out converter splice from driver side bose sub to amp RCAs. easy. have the gain at center, headunit at +2 bass and reduce to -5 to cut off all bass.
edit for wiring.
What amp?
About 100 watts RMS....
It is a LOT louder than the Bose 8"...
But it did Not take a Lot to be Louder than the Factory!!!!!
Here is the link that I have posted my set up:
http://forums.maxima.org/west-coast/...eoples-51.html
Do i need to buy a special adapter to get the sub/amp connected to the stock headunit?
I have an 07 se non bose stock system
No need to buy a new head unit or special wites for amp and sub install. I hooked my amp and subs to my 99 max stock bose head unit. All I did was some simple splicing. For the amp all you have to do is set up the 12 B+ to the battery and and the Ground to a bolt In trunk. For the amps REM wire i spliced it to the stock bose head units amp TURN ON SIGNAL WIRE. The only thing now that is needed is the RCA input wires. Since the stock bose HU Doesn't have RCA jacks, I had to modify my RCA wires and splice them to my rear speakers. So I cut the RCA wires in half and split the L and R wires so that I would have two separate wires now . Now that I have 2 separate wire
2012 amp inst
i have a 2012 maxima with the bose system. i added another amp and sub. i need to find the remote wire going into the factory bose amp so i can splice into it so i have a remote wire for my new amp. but i can't find one! someone told me it was the baby blue wire...this is not true. i spliced into it and my amp stays on all the time. please help!
melteye
May 16, 2016 12:02 AM
RealityCheck
Aug 5, 2015 06:18 AM
