Car shakes @ idle!!
Car shakes @ idle!!
hey my car just started doing this:
I'd turn it on, and then the idle seems a bit rough (it dips then it catches itself) then I'll get it going. Sometimes the shakes stop, but other times it keeps going. I was on the highway the other night and I could hear the engine "knocking". Please help! I have a roadtrip with the MAX down to Florida soon and I don't think I should drive her that far in that condition.
Not getting any codes off of it except Rear O2 sensor overheating but that has been there forever and since I don't live in an emissions state I don't worry about it.
Recent adjustments:
-Replaced cyclinder 3 fuel injector (w/ OEM)
-Replaced IACV (w/ Autozone part)
I did check the motor mounts and found the upper passenger side one a little loose so I tightened it up.
Not getting any codes off of it except Rear O2 sensor overheating but that has been there forever and since I don't live in an emissions state I don't worry about it.Recent adjustments:
Mine does this also..but very very intermittent..it really feels like a skip but i don't know..I just changed the fuel filter and air filter...but it still does it.. .I do know I need a water pump and am doing that this weekend...
Read, in the how-to section, how to check your fuel injectors and ignition coils. It will save you time and money. If it's not either, then you know you have a different problem. Also, check the resistance of the knock sensor (also in the how-to section) to make sure that you actually need one. Good luck.
Shouldn't I expect to get a misfire code if it really is an injector going bad (like I did when the cyl 3 injector went out)?
Checked fuel injectors here are my readings
cyl #1 - 23 ohms
cyl #2-6 - 16 ohms
the one I replaced before was cyl #3 I guess it's #1's turn to crap out on me. FML! I still don't understand how I don't have a code yet.
cyl #2-6 - 16 ohms
when i had this problem i had a dying coil pack i was throwing a blinking cel as a result of the multiple random misfires. i poppeed and replaced all the coil packs, well replaced inn te sense of making sure they were nice and snugg snugg, and the problem cleared up for me. if you wanna check your coil packs, WITH THE CAR OFF shove a screwdriver preferably a flat head into the coil pack, into the part that attaches to the spark plug, and touch it to some metal nbow turn the key it will spark, a very strong spark DO NOT TOUCH IT, you are good leave running for a few seconds 500-600 RPM wich is what your car shuld idle at if manual between 700 and 800 if automatic, this will cause a "fire" signal to be sent multiple times look for an iregularity or a pause in the sparks if none after about 5 seconds. turn off car remove screwdriver and move to the next one. if there is hesitation or gaps you found your culprit hope this helps
Get the car warmed up with a 10 minute drive. With all accessories turned off stop the engine. Unlpug the TPS connector (brown). Start the engine back up and let it settle for a minute or two. If needed adjust the IACV screw to reach around 700rpm. Stop the engine then plug the TPS connector back in.
A lean air/ fuel ratio will cause the rpm to dip down to 100 then pop back up while starting the car. It will cause the rpm to dip up and down while idling. It can also cause knocking while driving. I experienced all those symptoms when I adjusted the TPS position and the AAC valve position. You recently replaced the IACV so you'll need the ECM to relearn the air intake by temporarily unplugging the TPS:
The fuel injectors do not give you much warning when they are dying at all. I just did my valve covers including the rear and I ohmed out all my injectors at the same time. Four of them read 12.6 ohms while the other 2 read 11.8 ohms. Best believe that I changed them with some used ones I picked up for $50 for 6 with rail. Ohmed out those and they read 12.6 and replaced so that I don't have to go through that travesty of taking off the upper intake for a failed injector. Do it once, do it right!
Lakersallday24
Jun 16, 2019 01:35 AM
scarletsosa
Aug 17, 2015 09:09 PM
doobadoo
Aug 15, 2015 06:43 PM
