Post cat 02 sensor hard wire
I'm trying to hard wire my post cat 02 sensor in. can anyone tell me the wires
I have a red, a red with a black stripe, a black, and a white wire. wich is the heater wires what is the ground and what is the signal wire thanks need to pass emissions tomorrow
On the rear heated oxygen sensor, pin 1 is a red wire that goes to the ECM pin 107.
Pins 2 & 3 are in a shielded wire, your heater wires.
Pin 2 is white and goes to ECM pin 56.
Pin 3 is black and goes to ground.
Pin 4 is a red/black stripe and is 12 volts coming from the ignition switch and fuse # 34.
This is on page EC-156 of the 1997 FSM.
Don't have one? download it here:
http://www.nicoclub.com/FSM/maxima/
Usually the two wires that are the same color are the heater (reds, polarity does not mater), black is usually ground in general, and white is usually signal on O2 sensors. Usually...
With the link to the FSM that Dennis posted, you should be able to figure it out.
kjlouis
Nov 24, 2018 06:09 AM
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 3, 2015 07:53 PM
