FS 1972 Datsun 510 wagon, sr20det, clean title
LINKS TO VIDEOS:
http://www.youtube.com/watch?v=NTo1m_WWSYs
http://www.youtube.com/watch?v=rTSIQMqAayU
For sale 1972 datsun 510 wagon sr20det
$5000 as it sits
motor has blowby but still runs. Needs rebuild before driveable.
Dynoed 284whp with exhaust leaks and undersized intercooler piping. Since dyno, intercooler piping been upgraded and leaks corrected. Easy 300+ at safe boost level
Car does need a little bit of bodywork but frame rails and body are solid. Interior is complete and good but not perfect.
sr20det motorset
S30 front seats
autometer boost gauge (to be hooked up)
pretty new battery
rota RB 15x7 15x8 wheels with fuzion ZRi tires
3" turboback exhaust with flex section and magnaflow clone muffler
Forced Performance 20g turbocharger
external wastegate @ 1 bar boost w/ dump pipe
Evo8 FMIC
greddy oil filter relocation
NOS Koni Inserts (front)
cut 250lb coilover springs (front)
rear is stock with 1" blocks. Included in sale are 2" blocks and sensatrac shocks w/ helper springs
custom FMIC piping
T2/T3 adapter for turbocharger
Deatschworks 550cc injectors
K&N intake
Z32 maf
5spd transmission
high flow bosch fuel pump
custom driveshaft
XTD stage 3 clutch
240sx throttle cable
adapter for speedo so it works but not accurate
ECU tune by Jason@emance.
car professionally wired up (not a hack job)
Summit alumium racing radiator
new belts and hoses where applicable
NOS rubber motor isolators / custom mounts
custom welded and flipped front crossmember
custom transmission crossmember with rubber inserts.
heat has been bypassed but can work. No AC hardware
Battery relocation to back seat
enlarged shifter hole and transmission tunnel
relocated new fuel lines
relocated proportioning valve and driver side brake lines
$5000 as it sits
sr20det motorset
S30 front seats
pretty new battery
Evo8 FMIC
custom FMIC piping
K&N intake
Z32 maf
5spd transmission
custom driveshaft
XTD stage 3 clutch
maxima-junky
Oct 7, 2015 06:13 PM
fx4five
Oct 1, 2015 04:58 AM
you had some nice cars, why are you selling them? the **** wagon and the Cressida are awesome
