Violent jerking/bucking problem on 99 Max SE
My 99 Max has a bad jerking/bucking problem. I have tried to diagnose it myself, but I am at a loss as to what's causing it. It is more pronounced after the car has been sitting for a long period of time (overnight). It happens the worst in 1st gear, 2nd isn't too bad, 3rd usually doesn't happen, 4th & 5th doesn't happen. It usually happens from 300 to 2500 RPM. It bucks really hard unless I press in the clutch or try and accelerate through it. The problem tends to go away after the car reaches it's normal operating temp. No CEL's at all. None stored in the ECU either. Also, I have a slight decrease in gas mileage and a slightly rough idle.
As far as trying to diagnose this problem, after reading the forums, I went to the coil packs first, since those are prone to fail in the 99's. I swapped all 6 of my coils with my gf's Max, but still had the same problem. I changed the knock sensor, checked the MAF with a VM, all injectors with a VM, both were within normal specs. I checked the spark plugs, which looked fine.
My car might have a short in the wiring. My dash cluster goes haywire sometimes (gauges flicker and read incorectly, but only once and a while). But I don't know if this could be related to my problem. I'm leaning towards the problem being either a clogged injector or some kind of wiring problem. Any useful help would be greatly appreciated!
Assuming your a 5 speed, do you have an input shaft whine? Your tranny could be the culprit here, although you said it gets better when your car gets to operating temperature.
When was the last time you changed your gear oil?
I have a 5 spd. What would that whining noise sound like? I haven't heard any unusual noises. I got the car in January of 2010 and have never changed gear oil yet.
I had an issue like this a few years back. I had an automatic and when I would accelerate from stop, it felt like as if someone had hit me from the back. I had no clue what it was either, but I checked the tranny fluid and it was really low which was strange. Then I discovered that for some reason my tranny gasket had a tear so the tranny fluid was leaking.
You will be able to tell how old your gear oil is by how dark it is and how it smells. And you can gauge how much there was because they hold approx. 4.5 qts, give or take. The weight is 75w-90 too.
It wouldn't hurt and its routine maintainence and I would consider doing it soon if I were you.
For a 5 speed max, get 5 qts. of AMSOIL MTG (75W90) GL-4 Manual Trans/Gear Lube and that should/hopefully will correct the driveability issues. It's basically the same price as Nissan MTF but is synthetic and has twice the longevity and much better performance and protection. Start there and hopefully that is all that's needed.
U sure its not a slipping clutch? Does the car whine or make any noises. Take a real good look at suspension while u in there.
A slipping clutch will not make the car violently jerk or buck, it will slip and you will feel a constant loss of power if it is really bad. And usually you only notice it right after shifting, not while in gear for a while.
And why would he use Chevron Techron with the tranny? Isn't that fuel injector cleaner?
Sorry, using the wrong words, its a filter kit that you can get at pepboys and those type of stores. If your transmission was leaking, it is possible that rubber seal and the filter may be bad, so its in good terms to replace it. I have an automatic, so I know mine has that, but I don't know about 5 speed. I assume it should, someone with a 5 speed probably knows. Here is a link to the set.
http://shop.advanceautoparts.com/web...S_752832422___
How are your motor mounts and how long have you had this Max?? I ask because when I got mine, I would get into this rythm where the motor would buck. As the car surged the pressure of my foot on the gas pedal would change and It would snowball into something very embarrasing. I've since gotten used to the car and dont have that issue anymore.
It's definitely not a slipping clutch. I've had experience with a clutch going bad before. There aren't any noises either.
TPS
I had the same problem 97 max 5 speed. With car war and not running unplug the grey and brown connectors on the TPS (from drivers side fender looking at throttle body the connectors are on the right side of throttle body and they plug into the TPS), restar engine and let run for a minute or so, stop engine, replug connectors, restart engine and let run and depress accelarater 5 times (do not have to rev to high). I tried this and it took care of problem I hope it works for you.
I'm waiting on a local rep from Amsoil to get the shipment of synthetic GL-4 gear oil. I tried looking at all the local stores for some GL-4, to no avail. I figure it's worth a shot. Besides, it can't hurt to get some fresh oil in the tranny.
Back to the bucking...
Check the motor mounts. Open the hood, pull the e-brake up nice and tight. Put the car in 1st and start letting out the clutch to put some load on the engine. Make sure it doesn't move. Do the same with the car in R. The engine shouldn't move much at all. If you can see if lift up, you have a bad engine mount.
Check the TPS - Use a DVM. Make sure it's adjusted correctly. There is a procedure on here, use the search feature. Check the sweep with the DVM. Make sure it's linear and smooth with no drop outs.
Edit: Just checked TPS. It's within specs.
Wouldn't the O2 sensors trigger a CEL? I'm not sure if that's the problem. When I got the car, the dealer actually replaced one of them before they sold it to me.
Jus some ideas...
Dont think its motor mounts.
Well, I just put Amsoil GL-4 in my tranny. I still have the same problem. Does anyone know of a way to use the sound check on the rear injectors under the UIM? They're hard to get to. I might have to hand this one over to my mechanic...starting to run out of ideas
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
