are 18's too big? are 235's too wide of a tire?
are 18's too big for a maxima ? I have a chance to get some mazda 6 wheels , for 25 dollars a piece '
are 18's too big for comfort? I want a comfy ride , I am sticking with stock ride height for now. I was going to use 235/50/18's but not sure if thats too big for a 7 inch rim....
235x50R18 would have too large of an overall diameter. When I did the calculations for my 17" wheels, I found 225x45 and 235x45 would maintain the closest diameter to stock.
And back to the original topic. I wouldnt put these wheels on any nissan, the offset is probably up in the high 40s somewhere. It'll look like the wheels are hiding from the world.
If you really are set on getting these wheels, go with a 215/40 tire. Or maybe even a 205/40. Unless you wanna try to get the most wide track possible, which in that case, you shouldnt be looking at a 7" wide wheel in the first place.
wow my head hurts after reading all the "information" in this thread.
18's are argueably the perfect size for 4th gen. 235's are the prefect width for an 18" wheel for a 4th gen as it maintains nearly the same overall diameter. But, 235's are slightly too big for 7" width. proper size is not 235/50/18, its 235/40/18
referring to a 19" wheel in a 18" wheel thread helps...ahh i see now *smh*
with a 18" x 7" wheel i'd say run a 225/40 as i believe thats the exact size for a 7" wide wheel...you can run a 235/40 with no problems if you want, but i personally wouldnt
i mean unless we are talking about a b1tch that is like 4" tall and wieghs 235lbs......that may qualify is too wide.....
