RPMs drop and car stalls
My car is stalling 1 to two times within the 1st 10 mins of driving it. I think it must be something with the fuel injection system because the RPMS just drop out and it stalls up.
Restarting it is possible but i have to crank for about 10-20 seconds and eventually it starts up again.
Any ideas?
Thanks,
Any ideas?
Thanks,
Any ideas?
Thanks,
Any ideas?
Thanks,
for me it was MAF sensor. Did not get the check engine light but my MAF was bad.. try to find one in junkyard or borrow one from a friendfor couple of hours for testing .. used run anywere from 25$ and up. It's very easy under 5-10 minutes to do the swap
Wow, lets go do and buy **** that we dont need to fix a problem he doesnt have. Clean your IACV and MAF. If that doesnt fix anything THAN you can start further diagnosis.
/Thread Hopefully.
/Thread Hopefully.
Thanks so much everybody!!!!
I assume these are the directions i should refer to:
http://forums.maxima.org/4th-generat...g-dummies.html
yo i had the same thing happen to me and it turned out to be the coolant temp switch .it showed the needle at normal operating temp but the switch wasnt reading it right sooo the car would stall. i had the same thoughts your having, i changed that and it was all fine try it its only 26 bucks from the parts store.
Taking the car into the shop tomorrow for an oil change. I went to autozone yesterday - they pulled my codes - and they told me i had a bad engine coolant sensor. I'm not sure I have the know how to change it myself so I may have the gas station do it when i get my oil change. Is it an easy job?
forgot to mention clear ecu after install
haha im reading through this and this happened to me a while ago i ended up getting a new temp sensor and now she runs great.. and by the wat make sure u take the radiator cap off or ur gonna get some hot antifreeze on you.
he should be doing this job when the engine is completely cold
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
