FINALLY!! Custom Itouch in ashtray and Garmin in vent cluster pics+video
It finally all came together... Originally I built a Garmin into the place that my ashtray used to be but was unsatisfied with the fit, finish and location. Ive since revamped that one and its still for sale...
My next project was to build a better garmin into my vent cluster where it is more in direct line of sight while driving and is easier to manipulate up high. Plugs into my cigarette lighter and powers on/off with the car. Speaker is loud enough to hear though the other vent.
Most recently I wanted to integrate my ipod touch into my vehicle so that it plays through my car stereo, charges off the battery, and is removable at night or when necessary. Basically I had to buy a itouch "case" that covers the backside of the itouch and cut away at the ashtray door to fit the case and then bondo it in. Normally the ipod snaps into the case so i had to trim off the top of the case so the ipod could slide up and down to the cord/jack when installed/removed. I had to pretty much gut the bottom of the ashtray to allow for the pivoting of the cord behind the ashtray when its opened.
Video on youtube: http://www.youtube.com/watch?v=3O1QYqY6I_0
The garmin was more difficult for many reasons, there was more factory trim to cut out, sand down so it sat right, and then fill in where necessary. Also Once the unit was set in the trim piece, i had to go back and "trim out" the edge of the screen with bondo and flush it to the rest of the trim. The beveled edges and rounded corners were a biznatch to get right. This probably took me at least 40 hours here and there. It was done in stages and was caulked in for a while but that was crappy.
The ipod build was scarier because of moving parts, affixing of the cord, lots of dremel work to get the itouch case to sit in. However it was relatively easy because once the face of the ashtray door was pulled off and cut in two, the itouch case pretty much sits flat against the door so it practically flushed itself into place with a little bit of shimming on one side.
Hacking apart the bottom of the ashtray was easy. The only other difficult part was cutting away at the backside of the trim piece where the ipod cord ends up hitting against the shifter trim when closed. I never enjoyed sanding and painting too, that can be hard when the smallest scratch, bump or spec of dust can ruin lots of work.
Lucky for you, you dont have to! Fortunately the passenger vent can still aim over at me and the loss of one vent increases pressure/flow in the others.
Thank you for all the props guys, im pretty sure that this will be my shining moment on the org, so ill enjoy it while it lasts. Anyone think that an itouch would fit better in the left most vent by the blinker/light stalk?
hahah yeah i hear ya!
Very clean job man I just finished installing the Ipad into the dash also in place of the radio and I know how hard it is to make it look factory-like cause now I'm still in the process of sanding and painting. Much props to you man.
I am more open to the idea of producing the itouch docks for several reasons. The fit and finish was easier to achieve because the itouch "case" made for a perfect install to keep the ipod flush w the front of the door and the whole install was more common-sensical. If i happened to dremel away too much of the ashtray door, i can always bondo more back in. My only problem is putting a price on my time, and due to the amount of times that i have to let superglue dry, and bondo set up for sanding, and paint and sanding... your car will be lacking a shifter trim for about a month.
Feel free to PM me for more indepth conversation if you are serious about your own setup.
I think my next concept might be to install an itouch to the left of the steering wheel in that vent. The size of the vent is just about right, the only problem is the convex round shape of the vent and the ipod would be slightly recessed ipod--> |) <---vent exterior. The proximity to the steeringwheel and windshield might be an upgrade from the ashtray. Anyone have any thoughts/desires?
Thanks again everyone for the support!!
Looks very clean!
