CA FS: Complete 3.5 with 5 speed swap $1000
Located in soCal, complete VQ35 / 5 speed swap , $1000 with all the following, but there is a trick:
you need to take it with my car.
Which got into a rear end accident 5 month ago. Due to inspection/CHP/smog and a sxxx loads of inspection needed for the salavage title. I am just going to file non-opt in a few days. So you are going to need to have it towed, heres the detail:
04 VQ35 with 13xxx miles when i first bought it a year ago, I have put on about 20000 miles within the year, the entire swap and change over was done by me.
IACV adapter and cam adapter adapter from Stevenmax
Full timing gear from a 3.0 with all new tensioners and waterpump.
All new gaskets, seals and belts.
Fully functional EGR
ACT heavyduty clutch
All new engine mount except the MT mount
warpspeed Y-pipe
Stock MT ECU
Summitracing RPM switch with fully functional VI
ZERO oil leak.
Everything else is stock on a 240000 miles body, a white GXE with spoiler. Original paint is still shiny, I bought it from the original owner 2.5 years ago.
Except the damage from the accident the entire car is in excellent condition. I`ve been driving it for the whole 5 month since the accident. 5 speed tranny is original and has ZERO seal leak. There are no check light, I am always making 200 miles trip and constantly getting 23mpg.
Basically you will be buying a fully functional car HOWEVER I am going to swap out the new shocks, MAF, stock steelies and radiator with new tires to my brothers car. You will be getting a dead MAF, dead shocks leaky radiator and a set of 300ZX rims with good tires.
Those interested might take it as a complete 5 speed + 3.5 change over. While the rest of the car can be part out or what not. By looking at the interior you will think it has only 70000mi
, there are zero rip or tear .You can also get it to registered again if you can "somehow" get it to pass all the inspection.
I will post pic only if anyones actually interested. The car is located in 91733
Also got a few left overs from the 3.5 swap:
Set of 6 3.0 oem coil pack - $80 shipped.
04 VQ35 throttle body, un-hacked - $60 shipped
2002 VQ35 Pathfinder TPS - $25 shipped
K&N filter for VQ30 - $25 shipped
Engine stand X 2 - $25 bucks each, pick up only
Technosquare AUTO 96 ECU with fuel and timing adjustment, no speed limit and raised rev limit at 7200, worked on my 3.5 swap with only the auto tranny code shown $320 shipped SOLD
Excedy OEM replacement clutch, PP with throw out bearing. I had it with the 3.0 for a few hundred miles until the water pump leaked
and then had the swap done. - $40 shipped
NON-oem Auto tranny mount - $35 shipped
warpspeed Y-pipe
Stock MT ECU
ZERO oil leak.
, there are zero rip or tear .You can also get it to registered again if you can "somehow" get it to pass all the inspection.I will post pic only if anyones actually interested. The car is located in 91733
and then had the swap done. - $40 shippedNON-oem Auto tranny mount - $35 shipped
wow, you arent that far from where i am. I think i might have to take the 2 1/2 hour drive to look at this maybe i might take it. Is the car in a condition in which is able to be towed?? or is it just effed
The car is totally drivable and stock looking I`ve been going back and forth SD ever since.There are rear frame damage where you can see buckling inside the trunk and the driver side rear door gap was eliminated lol . Both trunk and door work but need to be slam shut. But at a distance you really can`t tell if theres any damages at all.
Did I mention it has a new ice cold AC while the AC pump was replaced right before I bought it.
Pic will be up tonight/tomorrow morning.
I'm in SD and would you be willing to swap your 3.5 and 5 speed into my 97 se 5 speed. Ive been looking to buy a 03/04 maxima but this might be better cause I love the 4th gen look but there is no way I could do this swap myself.
How are you expecting to sell this if you dont post pics, respond to inquiries, or anything? Im actually a bit interested with a HUGE chance of taking it off your hands but unable to gauge interest since youre MIA.
Its that time of the year again lol. Cars been sitting in the parking lot at work and we are due to move out in a few days.
and YES it is still available, more than a few members pmed me through out the years and non actually showed up
VQ'rInWLA sorry that I missed your pm. I will knock $200 off if you are still interested
Please see my original post for all the details, nothing has changed except that the car is now covered in dust
If nothing falls through I am going to sent it to the junkyard next door.
sdotcarter
Sep 2, 2015 09:53 PM
