grounding kits, are they worth the money?
hey quick question, I'm looking into these grounding kits that are for sale on here and i was wondering if anybody has had this installed this in their max and actually saw some results? do you guys think that its worth the money for these or no? if it makes any difference i have a 5.5 6 speed. any input is better than my own, thanks
I'd say so, especially since its a minor price for a minor mod. I built mine about a year ago (Big 3 plus both heads) and when I installed it I noticed a smoother idle and slightly quicker response. Plus with imports and their notoriously bad grounds and electronic component's aversion to bad grounds I'd say a grounding kit is cheap preventative maintenance.
Put one on my 4th gen. Def. helped with a starting issue I had and also made my lights brighter. At first I thought it was a just me, but even my better half noticed the change.
I recently installed a kit on my 5.5 AT that I purchased from shinjiduo. It definitely made a noticeable difference in the way the car shifts---much smoother and crisper while accelerating and braking (reduced hesitation). My headlights, which still have the factory HID bulbs, are also slightly brighter. I'd say go for it...the kit is inexpensive and it improves the driveability of the car. But you should check out the sellers' original thread for comments from fellow 6spd owners: http://forums.maxima.org/5th-generat...round-kit.html
here is his link
I made my own. Even with buying the bulky crimper for the brass grommets it was still under $40. I only Saved 10, but the crimpers are what put it over the top, something like $14 just for the tool. I really liked them and have used them since. The best part was that I was able to make all my lengths custom, so it was more satisfying then saving the $10.
That said, I didn't expect much from a mod like this, but wow, improvements all over the car. Lights, windows, startup...even the stereo sounded much better, (with added Sub before grounding kit was installed)
The custom kits are a good deal even at $50. If you don't want to waste time, just get one of them and bolt it right on. Takes mabye 30 minutes.
Same here but with 4 gauge welding cable. Figured it's better than what was in there stock plus the cable I used is heat, oil and abrasion resistant. Not to mention the cable tends to be a bit more flexible and conductive than an equivalent cable.
I guess I messed up my kit from Shinjiduo? The bolt on the battery wasn't long enough to attach the ground wire from the headlamps, so that wire is currently just chillin' on the metal, adding resistance to my electrical system.
I can't remember the other things that got grounded, but nothing changed for me in my six-speed. I'd recommend replacing existing wiring with nice, heavy gauge wire like they sell in the kits.
i got a 5.5 6speed to with a grounding kit...didnt help me at all lolll didnt notice anything different...
I'm not sure about the 5.5's, as I haven't put a set on mine yet, but I did notice a noticable difference in my 4th gen. The stock grounding points weren't in the best condition, so when I added my own ground kit, I noticed less light dimming when turning on accessories (such as the rear defrost), and prolonged life of the starter....since 4th gens love to burn those out.
go for it.
As far as grounding kits go. If u spend over $30 your being silly and wasting ur money. honestly hit up ebay they are like $25 shipped all day everyday:
http://cgi.ebay.com/ebaymotors/UNIVE...item588acadcda
If your stock grounds are in good shape then they dont do a thing. but if they are alittle worn, and if your running HIDs and have a system etc they help with light dimming and random misc. Its the reason why older car benefit from them so much.
man seems to be a hit or miss with this kit huh? some say that they like it others say that there is no point besides a better look to the engine bay ha. i cant say i really know what to do here. not to shift the topic of this thread but ii was looking into the nwp engine torque link brace too which is a little more expensive but these are the two upgrades that are on my radar at the moment and im having a pretty hard time deciding which one to go with here
i dont know what to expect thats why im asking others on here to see if they noticed any advantages after installing the kit. if they did what were they. for example this is why i post, some people say they see advantages and some dont:
Mar 12, 2020 12:06 AM
