P0420? need to pass inspection? look no further.
So its time for inspection, and you have a bad cat/hollowed it out
. or your looking to hollow it out or put a test pipe in but your kinda on the fence cause you dont want to throw a P0420 code, well if your car is 96-20xx i have just the thing for you!
http://www.o2simulator.com/index.php...40143058960191
I have put these in many of friends cars who are boosted/hollowed cats or test pipes WITH A CAT CUT IN HALF AND WELDED OVER IT cause they do check here in jersey. now mind you this will only work on an OBDII car/in a state where they dont do a sniffer test if you are OBDI this IS NOT for you.
Basically this gets soldiered in line with your downstream O2 and tricks your ECU that the cat is fine/present LOL and i have had many success stories with them and i thought many of you can benefit from this info
. or your looking to hollow it out or put a test pipe in but your kinda on the fence cause you dont want to throw a P0420 code, well if your car is 96-20xx i have just the thing for you!http://www.o2simulator.com/index.php...40143058960191
Mar 12, 2020 12:06 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
