Brake Lines recommendations
Sup all, excuse my ignorance, but other than building engine, turbo and all that, theres a couple things I am clueless about, thats brakes, and suspension.
Just now I saw liquid leaking from behind my front tires and turns out to be brake fluid coming from the top. So automatically I am assuming its the rubber 14year old line that cracked/broke (ofcourse ill inspect further later).
But my question is, what do you guys recommend as a replacement for all four lines? What are good quality SS or ruber lines available now days (im scared about ss from past horror stories on here). Any advice will be appreciated.
Turned out to be the caliper. Man i was so disappointed this morning, saw a second puddle, damn power steering hose somehow got loose over the years. Also see some liquid dropping right at the end of the tranny near the steering rack, I cant tell if its powersteering fluid, or brake fluid.
Goodrich SS lines for 8yrs - not a single problem. I'd buy em just for the ability to hang calipers safely when doing work. Stillen's got em for $108 in fact (and they get cheaper at their annual sale each year).
Nice! good to know. For now i just replaced the calipers, I def will be upgrading to SS after holidays. For some reason my passanger side wheel likes to lockup or provide more braking than the driver. Dont know why.
I guess thats where ABS is needed to distribute the pressure/flow evenly. I gotta hook my ABS back up since i have it disabled because one of the speed/abs sensors failed.
tell me how a line completely full of an uncompressible fluid takes time to propagate through a hose? that's just dumb talk. :matt93se:
All of the SS line failures I've ever seen have all been to user installation errors- rubbing against a body part or the inside of the wheel or something like that. The lines on my Maxima are 10+ years old and still working fine.
Goodridge and Technafit are both good quality parts and work great. used both for years and installed 50+ sets (and sold hundreds of sets) and never had a single line fail that was installed correctly.
I never said nuttin about lines failing.. All I was trying to explain is if you look at different cars the majority of the have one side with less pad than the other.. It probably came out wrong but you know what im talking about...
Actually I have no clue what you're talking about. the only time unequal line lengths are an issue is when you're bleeding brakes. you have to bleed the rears longer than the fronts because the lines are long and there's more fluid.
any other reason- propagation delay, uneven pad wear, etc, is just silly talk.
The reason pads wear unevenly is usually due to calipers sticking in one way, shape, or form. the line can be collapsed and not letting all the pressure out, which will cause the pads to drag on one side and they'll wear more than the other side.
if you have a bad/siezed slider pin, they can also cause issues with uneven pad wear, warped rotors, and all kinds of other fun stuff.
Also when I used the 300ZX master cylinder with the 300ZX BBK and didn't revalve the lines properly the car would pull to the right very heavily when the ABS was shut off. After re-routing the lines the brake pressure was even on the front calipers and the car stopped straight.
But really, these are all things that should have been taken care of before engine and turbo projects. Too much basic maintenance is overlooked for mods!
sdotcarter
Sep 2, 2015 09:53 PM
