NJ Very Rare Cygnett Unison i-x5 Ipod speakers, aux in etc.
1. Product:
Cygnett Unison i-x5 speakers that work with iPod and have aux in, usb connectivity and s-video out.
2. Specs:
3. Description/Condition:
i-X5 Features
Front Panel Features
Manual: http://www.cygnett-unison.com/UserFi...%280802%29.pdf
4. Price: :
$225 shipped
5. Pictures:
2. Specs:
i-X5 Features
- 1. Tweeter: 1” Magnetically Shielded Natural Silk Dome
- 2. Woofer: 5” Magnetically Shielded Paper Cone
- 3. Enclosure: Hand-crafted wood enclosure provides insulation of the acoustic components delivering a stable and superior bass response. Designed with a custom-made interior, the enclosure minimises vibration for distortion free sound and clear audio reproduction. Rear Panel Features
- 4. Power Indicator LED: Indicates whether the speakers power is turned 'ON'.
- 5. DC Out: When connected to the dock, this power cable allows your iPod to charge when docked.
- 6. Aux In: This port enables stereo audio connection between dock and speakers.
- 7. RCA Input: Used to connect signals from unbalanced, -10dBv devices. The white connector is for the Left input and the red connector is for the Right input. Rear Panel Features (continued)
- 8. Volume Control: The volume control allows you to set the output level of your i-X5 (Note: this function is independent of the iPod volume level).
- 9. Vent Port: This port aids in reproduction of very low frequencies by discharging frequencies below 50Hz.
- 10. 6.5mm Jack Output: Use the 5 metre speaker cable included to connect the left and right speakers through the 6.5mm jacks on the back of each speaker.
- 11. Power Switch: This switch turns the device on and off, The 'ON' position is marked with a white dot.
- 12. Power Receptacle: Accepts a detachable 3-circuit line cord in order to power the device.
- 13. Voltage-Select Switch: Provides 2 selections, 115VAC and 230VAC, and should be set to match the “house supply” (receptacle) voltage of the country or location in which the speaker is used. The 115V setting is correct for the USA, while the 230V setting is correct for most of the UK, Europe and Australia. This setting must be correct or damage to the speaker will occur.
4. Price: :
$225 shipped
5. Pictures:
knight_yyz
Nov 1, 2015 01:34 PM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
