MD 1998 maxima blk 5 speed, loaded- $1700obo
Old Jan 14, 2011 | 05:59 PM
phillyzj's Avatar
I will post pictures soon.
black with tan leather, 5 speed, 203k miles, SE loaded with every option but heated seats and side airbags. The car has after-market Y-pipe, pace setter cat back, CE coils, receiver hitch. Newer tires, UHP All Seasons, Bridgestone RE960AS with 8k miles on them.
This car was my daily driver for the last 5 years. I bought it with 110k on it.
Everything inside the car works, air, moon-roof (no leaks), climate control, etc. The volume control on the bose HU is unresponsive at times especially when cold, but that's the only real issue with the interior.
Exterior is in decent shape for it's age other than some slight damage on the passenger front. The only real issue is the upper radiator support is tweaked. With a new rad support and probably a front fender it would look pretty good. The bumper could use a little work but could probably be repaired. It looks good from 20ft away, but needs to be noted, i will get better pictures to show this.
Mechanically it could use some work. The car drives fine, lots of power, shifts smoothly, clutch doesn't slip etc. The trans does leak from the passenger output and there are slight vibrations under acceleration. This started when i replaced the passenger front wheel bearing, I accidentally cut the boot on the axle shaft. I bought a replacement shaft from NAPA and had vibrations, i took it back and got another one, still same issue so i'm not sure what it is. I could have messed up the output seal, or the carrier bearings could be on their way out. This is the ONLY major issue with the car.
UPDATE: i fixed the leak and the vibration and checked the carrier bearings, it's good to go.
Recently i replaced the front brake pads, passenger CV axle and passenger wheel bearing. I have replaced a few parts here and there over the 5 years that I've owned it but never anything out of the ordinary.
The car could also use an AC clutch bearing. I have the bearing but no time to do the work.
The main reason I'm selling it because i have 4 cars in the driveway and it's just time to move on. Without a lot of work i'm sure this car will last a while but i don't have the time at the moment to work on it.
1700obo
EDIT: I don't think it is leaking afterall. I saw something last night but i checked today and there was nothing there. I will put some miles on the car and keep an eye on it, but right now it isn't leaking.
Old Jan 15, 2011 | 07:50 AM
phillyzj's Avatar
Old Jan 15, 2011 | 07:53 AM
phillyzj's Avatar
sorry for the pictures of the dirty car...she cleans up pretty nicely.
Old Jan 15, 2011 | 10:14 AM
VisciousMo's Avatar
nice car, bumpfor you.
Old Jan 18, 2011 | 06:35 AM
phillyzj's Avatar
Bump, make some offers.
I also have a set of 18's and some extra parts, antenna assembly, drivers headlight, passenger mirror, etc that will go with the car.
I can't get to photobucket at work so i can't post a picture of the 18's, they are 5 sploke Sport Edition wheels that need tires.
Edit: here's a picture of one of the wheels. They are in OK condition but not perfect.
Old Jan 19, 2011 | 01:58 PM
jmartinez1092's Avatar
pm sent
Old Jan 23, 2011 | 06:32 AM
accordingtou's Avatar
VQ30 DE T
glws
Old Jan 23, 2011 | 07:25 AM
phillyzj's Avatar
Originally Posted by accordingtou
glws
Thanks for the bump!
As an update: I replaced the passenger side transmission output seal and no more leaks at all. I quickly checked for play in the passenger side carrier bearings and there isn't any. I found that the drivers side wheel bearing was the source of the vibrations and replaced it.
The only thing left is the AC clutch bearing which i can do if it's a deal breaker.
Old Jan 24, 2011 | 12:07 PM
phillyzj's Avatar
And SOLD, thanks for the interest
maxima-junky
Oct 21, 2015 05:17 PM
doobadoo
Aug 15, 2015 06:43 PM
09maxshawn11
Aug 14, 2015 10:07 PM
niZ
Aug 7, 2015 10:18 PM
