weird rattling around the tranny.
Old Jan 24, 2011 | 06:27 AM
K31J1m0N's Avatar
so i wake up feeling good this morning and i here weird rattling from around the tranny area. if i press the clutch in it silences but comes right back when i take my foot back off.seriously wut else can go wrong. wut could it be
Old Jan 24, 2011 | 09:03 AM
adroitcaptor's Avatar
Symptom - feeling good and problem happens
Correction - stop feeling good; you will then not be let down
Were you at a stop?
How do you know it was from the transmission area?
How is the sound effected when you are in gear, change RMP, change in speed, change gears, or comparing one gear to another?
Being vague on purpose - transmission issue.
Sarcastically - your imagination/schizophrenia.
Old Jan 24, 2011 | 09:11 AM
luke95gxe's Avatar
one of 2 things based on my experience bad throw out bearing or bad input shaft bearing heres a link of a bad input bearing listen at 9 seconds when he lets the clutch out
http://www.youtube.com/watch?v=8lboUTXyP7Q
Old Jan 24, 2011 | 09:22 AM
Under normal circumstances the throw-out/release bearing will only make noise when the clutch pedal is pressed (clutch is disengaged). It, however, will sound [similar?] to the above; most specifically, like there is 'gravel' on rotating the journal.
I would agree with the input shaft idea but do not like to make statements until I get more info. That is not to insult luke95gxe as he is most likely correct. However I like to discourage lazy posters and there is nothing to lose by getting the whole story.
Old Jan 24, 2011 | 10:38 AM
cashoit's Avatar
Agreed, need more info like maintenance schedule. any codes? How long u been hearing the noise. Any weird feeling. Change clutch lately?
Old Jan 24, 2011 | 11:52 AM
K31J1m0N's Avatar
i only started the car in the morning when it started. it hasnt thrown any codes or affectd any performace that i noticed. its just an annoying rattle. cant tell it its closer to the starter or actually in the tranny. all i kno is it doesnt do it at all when i keep my foot on the clutch. it even does it when my foot isnt on the clutch while driving
Old Jan 24, 2011 | 12:10 PM
phatboislim's Avatar
more than likely dude...start searching for a transmission...what you described sounds like before mine went..and i thought it was the TOB
Old Jan 24, 2011 | 02:13 PM
K31J1m0N's Avatar
yup.. imma just source out an lsd and call it a day
Old Jan 24, 2011 | 06:37 PM
i believe you have to get a LSD driver side axle...but double check on that
Old Jan 24, 2011 | 08:26 PM
97SEdriver's Avatar
this place is dead
no, you're right the driver side axle is different
K31J1m0N, you can probably drive on that for a quite a while before the tranny goes. When it starts to go, you'll know, I didn't have 4th gear for almost 3 months before mine completely went
Old Jan 25, 2011 | 09:14 AM
K31J1m0N's Avatar
yea the axel is definetly different. but yea imma check thoroughly around the tranny cuz i dont see how it just magically appears with a rattle after not even driving it over night
Old Jan 26, 2011 | 02:43 PM
dgeesaman's Avatar
Maintenance Monster
If you're near Harrisburg bring the new transmission by me and I can crack it open and check the condition of the internals before you install it. Takes about an hour to pull it apart and reseal it.
user 11122324
42
Jul 18, 2022 03:35 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
