Can an exhaust leak trigger the Service Engine Soon light?
Old Feb 6, 2011 | 12:38 PM
michaelm815's Avatar
My engine light came on today...
I'm up to date with maintenance on her and I don't really know what the problem could be.
I have a pretty bad leak in the Flex Pipe and haven't got around to getting it fixed yet, could it be that the leak got bad enough to illuminate the light?
I'm going tmr to have my mechanic run the code but trying to figure out what may be wrong.
Old Feb 6, 2011 | 01:20 PM
Rochester's Avatar
Step 1. Read codes.
Step 2. Listen to your mechanic.
Step 3. Research what you need to know.
Step 4. Fixed.
You jumped right to Step 3. Take a deep breath, and wait it out until tomorrow.
Old Feb 6, 2011 | 02:46 PM
zzmmrx0xmzz's Avatar
Possibly. I know my test pipes are not snuggly fitted and there is a leak which i need to retighten soon and my check engine light has been coming on pretty often the past few months.
Old Feb 6, 2011 | 05:05 PM
Stormzusmc's Avatar
yes it can
Old Feb 6, 2011 | 05:21 PM
captain jack's Avatar
get cheap code reader on ebay. comes in handy more than you think.
Old Feb 6, 2011 | 05:38 PM
Nexus67's Avatar
^Otherwise Autozone= free code check
Old Feb 7, 2011 | 05:43 AM
ken85's Avatar
test pipes usually set off the rear o2 sensor because the readings are different.
But yes an exhaust leak CAN cause a cel. It is EXTREMELY RARE it has to be a massive leak at the right spot.
Old Apr 27, 2011 | 09:55 AM
chico102388's Avatar
i have a check engine light for the rear o2 sensor wich i changed but keeps coming back on after reseting it. i have a massive leak in the flex pipe which is getting repair right now should get it back in an hour ill see if the light goes away.
Old Apr 27, 2011 | 12:38 PM
MerlotMax's Avatar
Think about it now - o2 sensor is a Oxygen sensor, it is looking for changes, from a preset value, in the oxygen in the exhaust. You have a "massive leak" ahead of the OXYGEN sensor
Old May 4, 2011 | 07:05 PM
bmwmike's Avatar
if the leak is before the o2 sensor then yes.
Dennis Twohy
Oct 1, 2015 06:01 PM
maxinout93
Aug 16, 2015 07:25 PM
Flores94
Aug 11, 2015 12:53 PM
