Test Pipes
P.S. test pipes are illegal in all 50 states, so if you have strict emission standards in your state, you're taking a walk on the wild side
Test pipes remove the factory cats. Instead of the cat getting in the way of exhaust flow, test pipes are just straight tubes (some are resonated to get rid of drone) that delete your factory catalytic converters.
I know I drive a 5.5, so I can't say much for the 7th gen, but I know I picked up a bunch of midrange torque when I swapped out my cat for a test pipe.
I'm currently running untuned, and the car does smell like a gas station.
Of course, it's pretty cool when I rev it up, and I'm shooting 12" flames out of my muffler.
Nothing a little bit of aluminum heat shield welded to the test pipe won't fix.
Actually for as high-compression as the Nissan motors are, with a full catback, a testpipe should see pretty good gains, even untuned.
The testpipe is separate from the y-pipe. At least on the 5.5. It goes like this:
Exhaust manifolds --> y-pipe --> Catalytic converter --> catback exhaust system.
Basically, the 13" (for the 5.5 gen) catlytic converter gets removed and replaced with a 13" piece of straight-through resonated exhaust piping.
I'm still currently running a stock y-pipe with gutted precats because I haven't had time to put my headers on my 6MT (they're currently sitting on my old 4AT...).
Now, a test pipe and headers will net you some really good gains. Of course, I don't think anyone makes headers for the 7th gen yet, do they? Or perhaps a y-pipe that deletes the precats?
It's just comical. That's all. I wasn't expecting it to happen...we were just fooling around with my car.
Hahahaha I sure hope you weren't going for the F&F look
I think on our 7th Gens its headers into a cat for each header, Y-pipe, another cat, resonator, y-pipe split into two mufflers. I could be wrong on there being 3 cats upwind of the resonator...
Racingline does build a Y-pipe, but with how **** the emissions tests are around here (trust me, my dad is a DEQ Emissions Control Manager in VA), I'd rather not have to worry about it.
Glad to hear the test pipes do give the 3.5 some extra oomph. I think I'll just stick with the Borla CBE and call it a day
I really hope somebody releases a set of headers to complete the y-pipe and cat back soon.I dont care if it has high flow cats or not! I think a reflash and some headers to complete the breatheing of this max will def put some fun in this car.
Far as cats go I always have went to the bone yard and took the heat sheild off old cars cats and welded onto my exhaust to have the appearance of cats on the car.The cops usually just walk around with a mirro on a stick to take a quick peak under the car for cats present.
Headers + eBay exhaust with Magnaflow muffler:
Headers + Testpipe + Same Exhaust:
Current setup:
Gutted pre-cats, test pipe, 18" resonator, sidepipe. The axleback will be back on the car soon.
It sounds like the 7th gens are set up exactly like the 5th and 6th. One precat off of each of the exhaust manifolds, a secondary cat off of the y-pipe, and then the catback exhaust.
The 5th gens see most gains from installing headers not so much from the straight piping, but moreso the elimnation of the precats. Same goes with the test pipe replacing the secondary cat.
Emissions around here aren't super-strict, so that's how I sneak by with my headers. But I'm also good friends with a guy who runs a smog shop that guarantees he'll get your car through emissions.
You didn't hear that from me, though.
I've got a few...
Current setup:
Hell no I wasn't.
Current setup:
Hell no I wasn't.
Hell no I wasn't.
).Lucky for you the emissions regs aren't as strict as they are in my county. I know a few guys who have to ask a guy, who knows a guy, who asks his brother in law to pass cars that otherwise should fail
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
