Dash Lights Out
Old Apr 18, 2011 | 12:19 PM
Noela's Avatar
Dash Lights Out
Hello,
I just realized last night that my dash lights are out. I checked the fuse box but could not locate any slot for dash/console lights. As suggested here in other forums, I checked to ensure that the tailiights are working
I would be very grateful for any pointers to resolve this.
Sincerely, Noela
Old Apr 18, 2011 | 02:44 PM
VQP0WER's Avatar
You did check to see if the dimmer switch isn't turned down?
Old Apr 18, 2011 | 04:25 PM
Noela's Avatar
yep.. i checked that, and it is turned up. rgds, Noela
Old Apr 18, 2011 | 04:26 PM
It's a fuse under the dash. Check the 7.5A's.
Old Apr 18, 2011 | 05:58 PM
Noela's Avatar
My apologies: I actually failed to turn the dimmer switch high enough ... feel silly !. But thanks for all your thoughts -- at least, i now know where the fuse is possibly located.
cheers - Noela
Old Apr 18, 2011 | 06:11 PM
TunerMaxima3000's Avatar
marker light fuse is under your hood. 10 AMP Glad to hear you got it fixed.
Old May 24, 2011 | 06:30 PM
GreenTeaFarm's Avatar
Where is the dashboard fuse...?
Im pretty noob at cars so I was looking around the forums because im having problems with my Maxima's dashboard lights randomly not turning on 70% of the time.
If im VERY lucky. The left side of the dashboard will turn on. The right side of the dashboard always turn on.
But the left side is the only part that has trouble turning on sometimes and it's pretty annoying.
I thought it could be a blown fuse so I had a guy come and look at the fuse for the dashboard lights but he couldn't locate where they could be.
I checked on the forum and some users said the dashboard light fuse is either around the 7.5? Somewhere under the hood? 10 A? Some Eelctrical parts area?
My main question is... Where exactly is the fuse for the dashboard. And if it's not the fuse would replacing the bulbs do anything?
Old May 24, 2011 | 07:15 PM
The fuse for the gauges/illumination is under the hood by the battery. It's a 10A, as I mentioned above your post.
It seems like you have a bulb that is about to die though, pull out the cluster and replace the bulbs, as an upgrade/alternate, I would suggest reading this thread if you're pulling the cluster out anyways:
http://forums.maxima.org/5th-generat...-works-10.html
Old May 25, 2011 | 05:30 AM
Ahh~ Thanks alot. I'll see if I can get some blue looking lights installed. You just saved me tons of trouble.
Old Nov 4, 2016 | 01:24 PM
Mahdi's Avatar
Dash light not working some times
Hello
I have problem with my nissan maxima 2001 CA33, dash light not working some times when driving ,just flashing and turn on again.so plz help to solve it.
Old Nov 4, 2016 | 03:19 PM
DennisMik's Avatar
Do the lights in the heater controls, radio, clock, window switches also not working or is it just in the speedometer cluster?
Old Nov 5, 2016 | 08:40 AM
Mahdi's Avatar
Just the speedometer light sometimes not working !! Another lights working well.
Old Nov 5, 2016 | 09:08 PM
DennisMik's Avatar
You might have connection problems on the the instrument cluster. Take the instrument cluster out and re-seat the wire connectors by unplugging and replugging several times.
Old Nov 6, 2016 | 10:44 AM
Mahdi's Avatar
I think the problem is instrument cluster control light switch because when i put on full it's working without cut.
Tnx bro
Old Dec 3, 2016 | 10:31 PM
gp540's Avatar
I am just running across something like this...
Dash lights inoperable with switch on, noticed that I step on brake it comes on and I head a click from passenger floor by firewall.... anyone?
Oops stupid google thought this was turd gen forum hahaah
Old Jun 8, 2018 | 12:44 PM
SteveOKid's Avatar
I am also having the same problem. Dashboard lights, taillights and the radio lights as well. All dont come on, but my signals and all other lights work fine.
Old Jun 24, 2018 | 05:09 PM
Bike'asz Peejay's Avatar
My 2002 nissan maxima starts but no dashnoard lights works an also alternator stop charing when it comes back in the alternator charges now its out any reason why.? Help.!
Raido works tail light works fine
cbrflyer919
Apr 7, 2003 02:07 PM
nathan123
Jul 28, 2002 11:38 PM
animal72
Sep 27, 2001 09:20 AM
