I have a 2000 I30, the dash piece's seem very tacky n sticky...i want to remove them and re-paint them....
I NEED HELP.........
THANK YOU
I had the same problem. My dash looks like a bear mauled it and I just found a replacement on craigslist at a local junkyard for Infinitis. The pieces should just pull off, but do it slowly. As far as removing sticky glues and what not, get a glue remover(car detail shops should have them, I know I work for one) it should smell similar to paint thinner if its the right kind. Just apply it and then wipe it clean with a soapy rag. After you have them paint em and get a good dash adhesive glue that body shops will have and you should be good. Not sure if this was what you needed but hope it helps.
