Sponsored by:
Sponsored by: CARiD
tell me its not the tranny......... plz
Old Apr 29, 2011 | 08:19 AM
Grand_hustle17's Avatar
O.k so apparently I'm not suppose to own a nissan maxima at all, id be really disappointed if I lost another tranny... so I'm driving with a buddy when all the sudden out of nowhere the car won't go stay into 2nd gear, I all the sudden came to astop n the car won't stay in 2nd, I can get it in gear then but soon as I get off the clutch ill watch it jump right back out.. had somebody sat in the car n put it in 2nd an tried holding the cables in place while the let up off the clutch, even with trying to hold the car in gear it pops right out n gives a loud grinding sound..... I'm sure with my luck it will tbe tranny number 10 smh
Old Apr 29, 2011 | 08:39 AM
ajm8127's Avatar
Did you use GL4 spec gear oil?
Old Apr 29, 2011 | 08:51 AM
phatboislim's Avatar
SUNNUVA!!!!
Old Apr 29, 2011 | 08:53 AM
t6378tp's Avatar
Turbo 3.5
damn, I hope 6spd trannies are cheap down there too
Old Apr 29, 2011 | 09:20 AM
Yes they are
Old Apr 29, 2011 | 10:00 AM
might wanna grab two. i hope its not your trans man, but its sounding like that.
Old Apr 29, 2011 | 01:42 PM
Legit6MT's Avatar
Yes they are
how cheap exactly?
Also go to autozone and buy some Penzoil Synchromesh.. and just make sure all your cables are routed properly. The only time that's happened to me is when the shifter bracket bushing was totally gone and would pop out of 1st while driving
Old Apr 29, 2011 | 01:50 PM
ajcool2's Avatar
Originally Posted by Legit6MT
how cheap exactly?
So cheap I have 2 trannys on stand by just in case mine breaks. We're lucky around here.
Old Apr 29, 2011 | 10:09 PM
krazy6's Avatar
Mine did that. It ended up being the synchro wire for 2nd gear. It dislodged and ended up getting lodged in 2nd gear and tore it up pretty bad.
Good luck man. Hopefully it's not the same as mine, but sounds exactly like what happened to me.
Old Apr 30, 2011 | 12:31 AM
What did you do?
Old Apr 30, 2011 | 08:52 AM
krazy6's Avatar
What did you do?
Had to replace 2nd gear, 2nd gear synchro, and the 3rd gear synchro.
2nd gear was chewed up pretty bad.
Old Apr 30, 2011 | 11:48 AM
How much was the rebuild?... I kinda wanna keep this trans n fix it
Old Apr 30, 2011 | 12:28 PM
So I'm sitting at the local popeys and I got curious if the car will go in gear with the car on without pressing on the clutch, tried 4th n no go but it seems like it would allow me to go in 3rd, (with that loud grind of coarse, I didn't force anything, just gently tried... soon as it grind I let it go.... that shouldn't be posible right? I am still a MT noob
Old May 1, 2011 | 07:05 PM
krazy6's Avatar
A lot, I'd just find a sentra tranny and swap your bellhousing on it. Super budget option right there.
Old May 1, 2011 | 07:12 PM
and1jr17's Avatar
its only a budget option if you can do the bellhousing swap yourself.. otherwise you need to factor in labor.. which is atleast an extra $200-$300.. asuming you can find someone willing to do it..
Old May 1, 2011 | 09:18 PM
krazy6's Avatar
It'll still be cheaper than a maxima trans. You can find a sentra trans for next to nothing.
Old May 2, 2011 | 04:59 PM
id also have to buy another axle...
HOKUSMAX
Nov 13, 2017 04:34 AM
riggy
Aug 6, 2001 07:35 PM
madmax97
Jul 4, 2001 10:10 PM
madmax97
Mar 28, 2001 08:57 PM
tunedup
Mar 9, 2001 08:00 AM
