engine light and brake light came on????
the car is running pretty good, for 266k miles.
i just changed my battery a few days ago. the old one was abou 4 years old.
had no issues, car starts, all elec works. but the battery and brake light came on tonight and stayed on.
no other problems?
no other problems?
Sounds like your altenator is bad. If you have a voltmeter, check the voltage while the car is running. It should be around 14.5 volts. If the voltage is only 12, then the altenator is not charging. Or take the car someplace like autozone that will check it for you.
Awesome reply!
The whine would most likely be a bearing going bad. That would not stop the altenator from charging, at least until the bearing totally self destructs and physically destroys the altenator.
Its also possible that it is not an altenator bearing making the noise. Don't assume - diagnose.
tsi6001
Oct 3, 2022 10:23 PM
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
