bumper adjustment? (pic)
Old Aug 4, 2011 | 06:27 AM
kel456's Avatar
any advice on how-to adjust the bumper on the pic? and damage components that i need to prepare for? thanks.
Old Aug 4, 2011 | 07:22 AM
njmaxseltd's Avatar
Either the grill is pushed back or the cover is pulled forward.
Looking at the alignment of the headlights, I would be pretty sure to guess the grill is back.
Take it apart and look what's come apart, it's pretty straight forward.
Old Aug 4, 2011 | 07:34 AM
kel456's Avatar
have not done anything in the front end before. so i guess i need to remove in the order of grille, headlight, corner lights and then the bumper?
Old Aug 4, 2011 | 09:55 AM
GGENIUS's Avatar
why dont you pull the grill off and look? there are bolts and clips holding the bumper on under the grill.
Old Aug 4, 2011 | 09:58 AM
GGENIUS's Avatar
also pretty sure you dont have to take out the corner lights and headlights to get the bumper off.
Old Aug 4, 2011 | 11:01 AM
kel456's Avatar
pull the grille just like that? appreciate some info on how to deal with the bumper if i don't have to take out the lights? thanks.
Old Aug 4, 2011 | 03:36 PM
GGENIUS's Avatar
by "pull the grill off," i mean unclip it from the headlights. itll probably be dry rotted so use needle-nose or a clip tool from behind to pop it out.
the bumper is held on by bolts and clips underneath the grill, bolts underneath the bumper connecting to the splash shield, and 3 bolts on each side where it meets the fender.
make sure you place a blanket down so your bumper doesnt scrape against the pavement.
Old Aug 4, 2011 | 07:44 PM
kel456's Avatar
thanks buddy. removed it with a flat head screw driver.
Old Aug 4, 2011 | 07:47 PM
GarageToys's Avatar
Originally Posted by GGENIUS
...make sure you place a blanket down so your bumper doesnt scrape against the pavement.
That is probably not an issue with that particular bumper.
Old Aug 5, 2011 | 03:38 AM
GGENIUS's Avatar
lol, well usually i dont want any new ones.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
ricky7780
Sep 24, 2015 06:50 PM
