Code PO300 Random Misfire
Old Sep 5, 2011 | 10:30 AM
BIG D MAXX's Avatar
Ok so i get a PO300 random misfire, on my moms 99 max i have checked coil packs all work great, injectors all spray, and has new plugs in it... ANY CLUES ON WHAT ELSE IT COULD BE? also it has a new MAF in it.. Any help would be appreciated.. Thanks in advance
Old Sep 5, 2011 | 11:31 AM
beatdown97's Avatar
t could be the knock sensor, it controls your timing, im not 100% sure it could cause a misfire but its possible, when the plugs were put in were they gapped properly?
Old Sep 5, 2011 | 11:48 AM
joesae01max's Avatar
Might have an intake leak some where - maybe the intake manifold.
Old Sep 5, 2011 | 11:53 AM
asand1's Avatar
KS wont cause misfire, only loss of power and low MPG. Why was the MAF replaced and did the misfire start after or before MAF swap? How did you check the coils? Working at idle doesn't mean they will work under load, cylinder pressure increases resistance at the plug gap.
Old Sep 5, 2011 | 12:14 PM
beatdown97's Avatar
before i changed out my ks i had a misfire under load, as soon as i changed it the stuttering and misfire went away
Old Sep 5, 2011 | 12:22 PM
BIG D MAXX's Avatar
KS was replaced when i did the VCG and Intake gaskets,,, MAF was swaped because it didnt work anymore would let the car go above 1500 rpm at idle, the misfire was there before the swap of the MAF and the new plugs i put in it. I checked coils by unpluggin them but not underload,
Now the wierd thing is that it doesnt do it all the time, and when it does it you can barely feel it but its there
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
