Price quote for changing transmission fluid & coolant is outrageous
I called the local Nissan dealer today inquiring about the cost of changing the coolant and transmission fluid. I was shocked because he told me it'll cost $150 for the transmission fluid and $130 for the coolant (drain and fill).
This is a lot higher than I expected
Why not do it yourself if you're simply doing a drain-fill. A dealer is going to charge you labor which is usually $90-$130 per hour and product costs plus they will charge you an hours labor cost regardless of whether it takes an hour or five minutes.
Both are easy. Just make sure to use d-matic nissan fluid for the tranny. And for a dealer that tranny service isnt too expensive. The coolant flush, ya thats high. Search the forums and you can see just how easy it is to do yourself.
Can you change the tranny fluid without dropping the pan? Kinda like changing the oil where you just remove a bolt and drain the oil?
http://forums.maxima.org/fluids-lubr...eck-level.html
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
