TX 2003 Infiniti M45 (Y34)
Old Oct 19, 2011 | 07:16 PM
Tony Two-Tone's Avatar
Item: 2003 Infiniti M45
Price: $9,000
Condition: Used
Accepting offers: Yes
Shipping: Shipping costs not included, please see item description.
Payment Type(s) Accepted: PayPal, Money Order / Cashiers Check, Cash
Description and Images:
Hey guys,
I've been fighting this decision since I bought the car but I've finally made up my mind and I'm going to sell my M45. It's a 2003 (Y34) currently sitting at ~116,000. Everything works, car is fully loaded minus nav and the heated/cooled seat option. So far I've done an intake change to a cone filter, custom Magnaflow (professionally installed), and had the windows tinted to 5% all around (excluding windshield and sunroof). Car is clean minus rash on the wheels and a little wear on the front seats(previous owner) with no dents or anything. Still has all original floor mats, trunk mat, owners manual, and both keys. This car has been really well taken care of and I hate to sell it, but I have other projects I need to complete. Asking $9,000 OBO
Specs from Newcars.com:
TypeVK45DE 4.5-liter DOHC 32-valve V8 with aluminum-alloy block and heads and molybdenum coated pistonsDisplacement4.5-liters/4,494 ccHorsepower340 hp @ 6,400 rpmTorque333 lb-ft @ 4,000 rpmBore X stroke (mm)93.0 x 82.7Compression ratio (:1)10.5:1Induction systemSequential multi-point fuel injectionValvetrainDOHC 4-valves-per-cylinder, titanium valves with continuous variable valve timing controlRecommended fuelPremium unleadedExhaust and emissions systemPerformance exhaust and three-way catalytic converter with closed loop feedback and electric dual-mode mufflerPlatinum-tipped spark plugsStandardMaximum engine speed6,600 rpm
Drivetrain2003 Infiniti M45Drive configurationFront engine/rear-wheel driveTransmission type5-speed electronically controlled automatic overdrive transmission with gated console shifter and manual shift modeGear ratios ( :1)
1st3.5402nd2.2643rd1.4714th1.0005th0.834Reverse2.3 70Final drive ratio ( :1)3.133Differential typeConventional
Body, Suspension & Steering2003 Infinti M45Body typeAll-steel unibody constructionSuspensionFrontIndependent strut with stabilizer bar and coil springsRearIndependent multi-link with stabilizer bar and coil springsSteering ratio ( :1)18.4Turning circle (curb-to-curb in feet)40.0Turns (lock-to-lock)2.9Steering typeElectrically-controlled vehicle-speed-sensitive power-assisted rack-and-pinion
Brakes2003 Infinti M45BrakesFront11.4-inch x 1.1-inch power-assisted
vented discRear11.5-inch x 0.6-inch power-assisted vented discElectronic Brake force Distribution and Brake AssistStandard4-channel/4-sensor /4-wheel Anti-lock Braking System (ABS)Standard
Electrical2003 Infiniti M45Electronic ignition systemStandard110 amp alternatorStandardLow maintenance 12-volt batteryStandard
Wheels and Tires2003 Infinti M4518-inch 8-spoke aluminum-alloy wheels, "Titanium Alloy" finish (7.5JJx18)Standard235/45R18 W-rated high-performance radial tiresStandardTemporary spare tireStandardFull-size spare tire with aluminum-alloy wheelOptionalLow Tire Pressure Warning System (direct reading)Optional
Exterior Dimensions (in.)2003 Infinti M45Wheelbase110.2Overall length197.2Overall width69.7Overall height57.6Track widthFront59.4Rear59.4Minimum ground clearance5.7Coefficient of drag (Cd)0.31
Exterior Features and Options2003 Infiniti M45High Intensity Discharge (HID) xenon headlights, with auto on/off feature (w/variable-off delay and variable-on sensitivity)StandardBody-color front and rear bumpersStandardGreen-tinted glass with dark-tint upper windshield band and UV cutStandardChrome door handlesStandardDual body-color power remote-controlled outside mirrors with passenger-side anti-glare coating and integrated turn signalsStandardHeated mirrors with timer, automatic day/night adjustment and mirror tilt-down (reverse gear)OptionalRear window defroster with timerStandardRear center high-mounted stop lampStandardBlack Chrome grille with large Infiniti logo emblemStandardBlack windshield moldings and chrome window moldingsStandardPower sliding glass sunroof with one-touch auto-open/close and rear tilt with safety featureOptional
Interior Dimensions (in.)
Front
Rear
Head room
39.8
37.3Shoulder room
54.7
54.1Hip room
54.6
52.7Leg room
42.1
32.5
Interior Features and Options2003 Infiniti M4510-way power driver's seat with power lumbar supportStandard4-way power passenger's seatStandardSojourner leather-appointed seats and head restraintsStandardClimate Control Seats (front)OptionalAdjustable front seat active head restraints and adjustable rear head restraintsStandardDriver's and front-passenger's seat back pocketsStandardElectrochromatic rear view mirror with compassOptionalStainless steel sill platesStandardDriver's entry/exit system with two-position memory functionOptionalGenuine leather-wrapped steering wheel and gearshift knobStandardGenuine wood accents on upper door trim and consoleStandardFully-molded simulated leather trim on front/rear door armrests and front door pocketsStandardCeiling-mounted assist gripsStandard
Capacities2003 Infiniti M45Seating capacities5Interior passenger volume (cu. ft.)91.0Cargo volume13.4Fuel tank (gals.)21.1Engine oil (qts.)7.1Engine coolant (qts.)8.9
Curb Weights2003 Infiniti M45Curb weight (lbs.)3,851Weight distribution (% fr/rr)54 / 46GVWR (lbs.)4,830
Audio System2003 Infiniti M45Bose 225-watt premium digital audio system with AM/FM/cassette, 7-speakers and steering wheel audio controlsStandardRear window diversity antennaStandard6-disc cartridge type CD autochanger (glove compartment mounted)Standard
Safety and Security Features
2003 Infiniti M45Dual front seat side-impact supplemental air bagsStandardDual front supplemental air bags, dual stage inflatorsStandardSupplemental side curtain air bag, front and rear, roof mountedStandardActive front-seat head restraintsStandardShift interlock systemStandardChild safety rear door locksStandardLATCH system: rear child safety seat tether anchors (3 in rear parcel shelf, lower rigid bar anchor with 2 positions)StandardFront seat belts with pretensioners and load limitersStandardEnergy absorbing steering columnStandard3-point front seat belts with adjustable upper anchors (passenger side ALR/ELR)Standard3-point rear seat belts (ALR/ELR in all positions)StandardHood buckling creases and safety stopsStandardFront and rear crumple zonesStandardBody side reinforcementsStandardVehicle Security System with indicator lightStandardRemote Keyless Entry systemStandardFirst aid kitStandardElectronic master ignition key - Active (2), valet key included in master keyStandardEmergency wallet keyStandardInfiniti Vehicle Immobilizer SystemStandard
EPA Mileage Estimates2003 Infiniti M45City17 mpgHighway23 mpgEPA ClassificationMid-size
Pics:
Please feel free to let me know if you have any questions. Thanks!
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
trsandrew
Apr 8, 2016 06:45 PM
RinconI30
Nov 10, 2015 10:55 PM
trsandrew
Oct 25, 2015 02:47 PM
