Forced Induction Sell your turbos, supercharger, nitrous, and related items here
RI FS: Brand New PLX Wideband!!
Old Nov 19, 2011 | 07:30 PM
inspiredbykev's Avatar
You should thank my D***
Brand new Plx devices sm-afr iMFD Sensor Module Wideband Air/Fuel Ratio; comes with wire to connect to a laptop $175 FIRM!!
SOLD
Air Fuel Ratio Sensor Module
The PLX Air Fuel Ratio Sensor Module accurately measures the precise wideband air fuel ratio (AFR) of any internal combustion engine. Up to 32 Sensor Modules can be daisy chained together in the PLX iMFD system. This Sensor Module can also be used as a stand alone unit capable of interfacing with 3rd party hardware.Works with gasoline, bio diesel, ethanol, methanol, E85, LPG, and CNG.
iMFD SM to USB Adapter
The SM to USB adapter is a low cost solution to data logging all of your iMFD sensors in real-time to the PC. It's operation is simple. The SM to USB adapter simply converts the iMFD serial stream into USB for your PC to recognize and interpret the incoming data. Data is constant at 10Hz regardless of the number of sensors you have connected to the iMFD daisy-chain. This adapter is fully compatible with PLX Logger 3.0 (Free license). This is great to have if you're on the dyno and you have a laptop handy to log all your data. Remember that with a DM-100/200 OBD, you have access to 4 programmable sensors that you can stream through the iMFD Daisy Chain. This feature is commonly used for picking up vehicle speed, RPM, Load, and Throttle Position.
Old Nov 26, 2011 | 07:38 AM
someone buy this it's BRAND NEW and complete
Old Dec 8, 2011 | 03:23 PM
bump
Old Dec 18, 2011 | 09:05 PM
X GARGOYLE X's Avatar
why are u selling it??
Old Dec 19, 2011 | 03:15 PM
I decided not to put any more $$ into my car. This has been sitting in my room for a long time. This a steal and a great wideband!!
Old Jan 8, 2012 | 09:57 AM
someone buy this
Old Jan 13, 2012 | 12:58 PM
nismomaxct's Avatar
So, this doesn't come with a gauge, correct. Will you do $175 shipped to 02562 (Mass)?
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
