Turbo on maxima?
That would be interesting, however my concern would be the limiting factor on how much power the CVT could handle.
What this car would benefit from is better off the line performance. Once this car does get moving it's actually quite impressive. A turbo isn't really going to address the standing start acceleration issue very much. I wouldn't even waste the money with one on this "daily driver" car.
In my mind it always seems to come back to the CVT. The Achilles heel of the drive train for the hot rodder.
fwd isn't the problem CVT can't handle the heat
the altima 3.5 blew his UPGRADED cvt why u think I haven't installed my turbo kit I just got sitting in my basement its Def not the money cause for $2000 it could get piped n installed with injectors 440cc
I wouldn't even bother with Turbocharging, if you're gonna do any boosting at all then I believe supercharging is the way to go on a very low boost setting of no more than 5lbs.
http://www.greencarcongress.com/2012...-20120126.html
I have been researching this quite awhile, Can't even find the turbo kits or supercharged kits for the Maxima. If so, link me. I was thinking about putting a shot of nos in the whip, Idk though, eventually in a year or 2 I am going to be getting another car and getting rid of this one, So I think it would be wise to just keep it simple with things I can take out easily/off easily.
The famous words of saying that its impossible to put a Turbo in the Max bc of CVT is wrong. Anything is possible, things get accomplished for those who work hard research hard, have the time, and money to do these things.
^^^The guy made a valid point on saying why put a Turbo on a DD car. That is true, not worth it unless you have a few other cars to play with.
HA! You guys think the CVT can't handle it?? I don't think the VQ in these cars can handle it. I really thought they were pretty bulletproof, but after my last oil analysis, I have SERIOUS concerns. After beating the **** out of my 2007 Altima 3.5SE, it had PERFECT oil analyses every time.
This car (2010 Maxima)...is highly unpredictable and, apparently, kind of fragile. After 6000 miles on this oil change and frequent redline (new RL y-pipe installed) to check out the new power....my lead was elevated as well as iron...indicating bottom-end wear. And this isn't the only time the lead and iron (and copper and aluminum) have been elevated.
Essentially, I think Nissan has changed something with the added 20+hp to make these motors a bit weaker in terms lf wear.
Either way....the CVT has taken a beating and been great with my car. The engine concerns me. I don't think it would handle boost without some bottom end upgrades.
Late,
Trav
Late,
Trav
WTF i have 124K Miles what non-sense you speaking about the motor....the motor is fine the CVT def got weaker @ the mileage im @...i actually took the car to nissan in hopes i could get a new tranny but they didnt wanna replace it they said it was "fine"
Late,
Trav
MAXSE5SPD
Aug 23, 2015 12:06 PM
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
