CT parting out 3.5 maxima lots of parts
THIS IS A COMPLETE PARTOUT
Parting out my maxima, stripped first gear on transmission is the only issue, brand new sway bar links, ball joints and outer tie rods. As it stands the car has a fully built 3.5, obx long tube equal length headers, resonated test pipe, knock off megan catback, mint condition black leather and full led inside. The car is being parted out or everything can be had for 3500$
prices do not include shipping, will not ship large parts
Motor SOLD
Includes
-Total Machine work to block and heads $1666
.020 over bore with HP Pistons
Decked heads
Polished/ balanced crank
Balanced Rods
Shot-peened/ glass-beaded rods
Ground Valves and Seats
Vacuum Test valves
Etc…
-New OEM Parts $700
350z HR valve springs double shimmed
350z Rev-Up Rod Bolts
350z Rev-up oil pump
350z main studs
NISMO 350z Thermostat
New water pump
New Valve Seals
All new O rings, seals, and gaskets
All new timing chain, tensioners, guides
6th gen valve covers
Knock Sensor
Aftermarket Parts $1900
HP Pistons
JWT Knockoff Cams
Cometic Head Gaskets
NWP Intake Spacers
Greddy Emanage Ult.
SARD Fuel Pressure Regulator
Misc Parts…
350z Injectors
Polished Pathfinder Throttle Body
TB Adapters
Cam Adapters
Ported/ Shelf cut Upper Intake manifold
Polished UIM
Ported Lower intake manifold
Port-Matched all intake connections along with spacers and gaskets
K&N Filter with Prefilter
Poly Filled Motor Mounts
rebuilt 2000 lsd 5spd trans first gear is stripped, all other gears work fine, first gear only needs to be replaced, no problem shifting or going into other gears includes a stage 2 clutch with about 20k miles on it. 300$
3.0 with about 150k miles on it includes codeless 00vi setup along with a perfectly working 5 speed trans, only needs new clutch, ready to drop in, timing and everything already on it including entire wiring harness 600$
Black leather interior in mint condition 550$ for the seats front and back
3.5 equal length obx headers, bolt right up to 3.0 SOLD
custom dual sides 2.5in exhaust with porsche tips 200$
megan knock off exhaust SOLD
resonated test pipe SOLD
obx short throw shifter 20$
b&m knock off short throw SOLD
extra cross member with poly filled motor mounts SOLD CROSS MEMBER STILL AVAILABLE
stock cat SOLD
progress rsb 60$
cf hood needs a new clear coat sold
knock off place racing cold air inktake sold
2 brand new snow tires, 215/55r16 100$ mounted and balanced if you bring me rims
stock 5 stars, painted black because the original paint looked like crap, will trade for your wheels and tires, plus cash depending on the wheel
2004 6 spoke 18s with BRAND NEW tires 550$
lowering springs SOLD
pm me for prices of things I forgot and more pictures
old engine
new engine
interior
interior filled with leds
exterior
have all stock parts
r34s sold
most recent picture
Motor SOLD
Includes
Decked heads
Balanced Rods
Vacuum Test valves
Etc…
-New OEM Parts $700
350z main studs
New water pump
New Valve Seals
Knock Sensor
HP Pistons
JWT Knockoff Cams
NWP Intake Spacers
Greddy Emanage Ult.
Misc Parts…
350z Injectors
TB Adapters
Cam Adapters
Polished UIM
stock cat SOLD
progress rsb 60$
old engine
new engine
interior
exterior
r34s sold
most recent picture
yeah, I can send you some today if your interested
I know how you feel, but just let me know because the engine still has to get pulled from the car and the emanage is spliced into the harness and I would prefer not to rip it off and seperate
sale pending on lip, obx shifter and test pipe
obx headers, catback, and hood sold
Well picked up my hokd today... puctures do that 3.5 no justice...damn nice engine setup and if i had the cash it would be mine!!! Guys buy this mans stuff he needs it gone.. for what its worth i didnt see a spec of rust on radiator support and leather seats are MINT.
And the engine currently has a sale pending, will post of it falls through
