Anything else I should do while I'm in here?
Changing valve cover gaskets, knock sensor and intake manifold gaskets. Going to clean the egr tube, iacv and pretty much anything I can reach.
Clean EGR tube/ Replace gaskets.
Give the IM a clean as well/Replace gasket.
Clean TB/Replace Gasket.
Spark Plugs.
Spark Plug tube seals.
Clean IACV/Replace gasket
Replace PCV Valve/Grommet, Also replace the hose the goes to the PCV Valve
Since the IM is going to be off, its a good chance to replace the coolant line that connects to the TB and IM if I am correct. I forgot what its called. Someone correct me on this.
Replace your air/fuel filter.
Spark Plugs.
Spark Plugs.
Replace PCV Valve, Also replace the hose the goes to the PCV Valve
Since the IM is going to be off, its a good chance to replace the coolant line that connects to the TB and IM if I am correct. I forgot what its called. Someone correct me on thing.
Spark Plugs.
Spark Plugs.
Spark Plugs.
(no need to buy OEM IM gasket if you do this mod)
