Replacing rear lower strut bolts/nuts??
I've done some searching on replacing struts and all that, should be a very simple job using the quick strut assemblies. I saw 1 mention of a best practice of replacing the nuts on for the lower mount on the rear struts. You guys that have done this job a few times, do you typically replace those nuts? Just called a local dealer and it sounds like those bolts/nuts are getting hard to come by. Does anyone happen to have size information for those so I can at least pick up some bolts/nuts from the hardware store that I can throw in there in case I break one or something? I'm guessing the reason for replacing the nut at least is because it looks like a deformed lock-nut which are supposed to be use once and done, For locking I could just clean it and throw some loctite on it. What do the rest of you guys do?
TIA
TIA
Yeah, I guess breaking one wasn't the right thing to put there, it is a pretty darn stout bolt. I'm more worried about the possibility of too much rust from a few years of hanging down where it does. And, since that nut looks like it has a deformed lock feature sometimes those can damage threads and such. I'm thinking I'll just soak the lower bolts with PB blaster for a couple days, then when I re-install just clean 'em up and throw some loctite at it. Thanks a lot for the input.
anyone know the size and thread pitch of the lower strut bolt on the rear struts? When I undid mine on one side, the threads on both bolt and nut got all flattened out and cross-threaded.
Tried the hardware store display where you try to thread the bolt into a bunch of different size sockets, but there's too much of an extension on the bottom of the bolt for me to be sure exactly what size it is.
I ended up having to cut my bolts since they were stripped and so was the stupid little bracket thing. I just brought what I had to the farm supply store and got grade 10.9 bolts the same size/length, works great.
I'm about to do this job as soon as it warms up here in philly. I swapped in FCS Struts all the way around this past summer, and I stripped the rear left strut pin and nut in that bracket thing. I got the pin and stripped nut back in, but not tight enough so now there is a little rattle in the back when driving over a bump or uneven pavement. Got my replacement pin and nut from nissanpartszone.com.
So I went to replace my rear struts and these damn bolts won't break. My impact wrench tried to round the head of the bolt itself so what is a relatively easy job just got harder for me. I may need to take it to a shop to have them broken. I even added heat with a torch and the bolt started to turn but the damn nut started turning with it to.
I may need a shop to weld than nut so it doesn't move, then try to break the bolts free. Damn New England winters I tell ya......
My issue at this point is that it's spinning with the bolt now. I was using a MAP to hit it because it gets hotter than propane.
Well, I don't think that will be a bad thing since I had to cut and replace my cat bolts a couple weekends ago. The only issue is that the lower strut bolts are going to be too big for a dremel to get thru so I'll have to invest in a real cutter.
No just get the reinforced cutoff wheels for the dremel and cut 2 slots thru the nut.i use those wheels all the time or goto HF and get a $20 grinder and a $5 pack of 4" wheels
I'm an HF head so I plan to just get a cutter from them, get the warranty and swap it when it breaks. It will do the job much faster than the dremel. My air hammer helped to finish the job when I did the cat bolts thought so I didn't have to cut all the way thru with the dremel.
good luck finding it.. i got the specs but nobody caries it especially with that particular shoulder. Its 12m-1.25x70 with a 10.9 grading. Your best bet is ordering it through Nissan for like $3. Ace hardware doesn't carry it and neither does any of the nut and bolt specialty shops around here either.
Huttig2009
Sep 25, 2015 03:31 PM
MaxStock
Aug 14, 2015 09:59 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
