blower mtr fuse keep burnt, help needed!
Old Oct 29, 2012 | 07:43 PM
erictown's Avatar
Maxima 2000 SE.
all of a sudden, my blower motor fuse burnt out. They are 2 15Amp fuses, all burnt. OK? I put new ones on, get burnt in 1 day. test done as below:
turned blower motor on, no problem.
turned on AC, no problem
manully upspeed blower motor, no problem
maunlly downspeed blower motor :---- flash! and fuses are gone....
I took the resistor out, it feels warm, some corrosion found on surface.
My question: is the fuse burnt out because of resistor expired?
Thanks in advance
Old Oct 29, 2012 | 08:11 PM
DennisMik's Avatar
I don't think the resistor could be doing this. The way the fan motor works is that one side of the fan motor is connected to the fuses. To make the fan spin, the other side of the fan motor is connected to ground. For high speed, the fan is connected directly to ground. For slower speeds, the resistor gets connected between the fan motor and ground.
Translation - you have a bad fan motor.
Old Oct 29, 2012 | 08:27 PM
erictown's Avatar
I've just done blower motor service, WD-40 to axis bearings. no extra resistance felt when I spin it today.
Old Oct 29, 2012 | 09:03 PM
DennisMik's Avatar
All that means is that the bushings are good. The brushes that ride on the communtator are probably worn out.
Old Oct 29, 2012 | 09:16 PM
RR5's Avatar
RR5
Checked the FSM yet?
Old Oct 29, 2012 | 09:29 PM
erictown's Avatar
sounds good! checked. don't find close issues. temp control well, motor runs good, fuse..... burnt......
ShocknAwe's Avatar
It happens when you turn it down? Might as well replace the resistor
Old Nov 1, 2012 | 10:31 PM
erictown's Avatar
problem solved. After disassembled motor and the resistor, I found some small rust and burnt spot around 3 welds. They're actually getting too close because of corrosion between them. short circuit must be happenning somewhere sometime. I cleaned around all welds. Now no fuse problem.
Thanks fellows.
Old Nov 5, 2012 | 09:01 PM
Amave's Avatar
came in to post this
when rust gets built up on the resistor contacts, it literally " adds " metal which in turn lowers resistance and when you lower resistance, you increase amperage , and when amperage gets increased and it exceeds the current rating on the fuse that protects the circuit....***POP!*** It blows the fuse
Just some FYI
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
silver_i35
Aug 3, 2015 11:20 PM
