Offset help
Old Oct 30, 2012 | 08:28 AM
xiong347's Avatar
Offset help
I found some rims on craigslist with winter tires and the seller says the offset on the rims are 50 mm is that to much for a 95 max will it clear my calipers?
Link to craigslist posting. http://milwaukee.craigslist.org/pts/3373331151.html
Old Oct 30, 2012 | 08:34 AM
Amerikaner83's Avatar
max rims iirc are a negative offset of -45, these are +50...
If they work, they'll be HELLA sunk in.
Old Oct 30, 2012 | 08:36 AM
xiong347's Avatar
Takin that as a find some dif ones.
Old Oct 30, 2012 | 08:37 AM
check what I said re: offsets, but probably, yes.
edit -
http://forums.maxima.org/tires-wheel...ing-years.html
I may be wrong on the offsets, they may be +40 on the max
http://en.wikipedia.org/wiki/Offset_(wheel)
Old Oct 30, 2012 | 08:43 AM
xiong347's Avatar
edit -
Yea i thought it was 40 rite not negative then the would be pokeing out really far. Lol
Old Oct 30, 2012 | 08:51 AM
if Max offset is 40 and these are 50, they'll likely fit, but they will be about 10mm further in. THAT's what I was thinking re: offsets. A larger offset moves the wheel inwards, a smaller offset moves it outward.
Old Oct 30, 2012 | 03:35 PM
chongher's Avatar
Yes the rims will be sunkin in. You will have to get wheel spacers for it to sit flush and some pretty thick ones too.
Old Oct 31, 2012 | 03:41 PM
xiong347's Avatar
chongher u wouldnt happen to be hmong?
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
