Labeling the engine before you do a head gasket set install
Got my white paint market and my black sharper and labeling tape.can anybody walk me thru it on a 1991 NIssan Maxima?????!!!!!!
lol u guyz
anyway, the disassembly is relatively straight forward.
For me, pictures work better than labels for the wiring harness, but vacuum lines aren't as obvious.
Basic instructions would start with removing the timing belt, then remove the intake.
how-to's can be found in this thread (drain the coolant before beginning, it will save some really nasty messes during the procedures):
http://forums.maxima.org/3rd-generat...-tutorial.html
as for removing the head, pull the valve cover(s) with the #3 Philips screw driver, then remove the heads (10mm allen socket, and a good breaker bar, not a ratchet with a cheater bar). Find the torque pattern in the FSM that Pearl linked to above, under the engine mechanical section. If you don't break down in the proper order, you risk warping the head.
using a sharp scraper, gently (VERY gently, don't gouge) clean the head and the block from left-over gasket residue. clean with a rag soaked with a good solvent, to remove any residual gunk.
If you have some, spray head gaskets with copper spray, assembly should be more (or less) the reverse.
Subject: Hater
That link to that fsm **** sent a virus to my computer.took me 5 hours to fix it .thanks for that stress load !!!!!!
Subject: Hater
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
