99 max not starting after changing knock sensor
today i plan to change my knock sensor, after changing the knock sensor an put everything back the car wont start im getting fuel but no spark. use my obd2 scanner an keeping code p0335 crankshaft sensor A change sensor but same thing no start looking for some help here plz
the car had a few problem when i bought it. i use the scan tool an the ks, multiple misfire code came up an hesitation when u drive it an wont past 2500
what i change so far
knock sensor
i change injector rail an the skipping went a way for a few only when u drive no u hear the skipping an bucking an hesitation
knock sensor
You should have prefaced that info to begin with. Chances are, you replaced the KS unnecessarily, as it's often a piggyback code to other codes. Fix the real problem, and the KS code goes away.
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
RealityCheck
Aug 5, 2015 06:18 AM
