Is There A Differance Inengines??
Re: Is There A Differance Inengines??
Originally posted by bigballen
IS THERE ANY DIFFERANCE IN THE 2000 MAX ENGINES AND THE 96. IF SO WHAT IS IT AND CAN IT BE PUT ON THE 96. ITS THE SAME ENGINE PLATFORM SO WHAT THE FU#%IS THE DIFFERENCE.
1. stop shouting. please use lower case. THANK YOU!!
2. a 2000 maxima has an engine with 222 horsepower
3. a 1996 maxima has an engine with 190 horsepower
hmm. installing a 2k engine in a 96.. interesting.. i will let others tell you about that one..
The hardest part would probably be getting all the electronics in order. The main differences in the engines themselves involve the intake system, cams and exhaust system.
But, a swap like this would cost more money than the mods required to get 222hp out of the 96 motor.
So when you comapre cost versus benefit, it's not a good plan.
the engines in the 4th gen and 5th gen's are basically the same. The 5th gen has a much more efficient exhaust and intake system, just as mzm said. If your really gonna do a new engine drop try to get your self that 6speed tranny -woohoo!- fun! If you do that you're going have to do a couple of minor changes in your cockpit
Originally posted by SuDZ
Best bet is probably just upgrading you 96 with aftermarket parts. Not gonna be worth the hassle other wise.
SuDZ
SuDZ
[QUOTE]Originally posted by mzmtg
So when you comapre cost versus benefit, it's not a good plan. [/QUOTE
not wanting to swap just wanderd what it was that made it have more horses then and the mods on top of what i have created]
difference in engines
if the engine is the same then i need what to make it the same. if it is a intake then i would buy a performance mod but stuff like intake manafold then thats a different story. heads are reworked ? maybe? i would like to know just what it is that 5 gen has that we at 4th gen dont then maybe i could find a guy that cut his speed limiter in his ecu and lost the car at 140+ and get the parts at a junkyard or something just thought i would ask. it would be nice to start at 222 than 190..
Intake manifold is the key. The 5th pulls hard all the way to redline. The 4th gen because of it's manifold design was made more for low end torque. It's a compromise on 4th gen because it lacks the variable intake manifold. Get the 5th gen manifold to work on your 4th gen.
ok is that all. and also is that y the specs are the same for 0-60 times. is there any other part of that engine or car i need to look for. is it a direct fit or will i have to get help from the shop guys with all the tech stuff what about the ecu would it do any good to try to put it in as well. thanks alot for your input.
What you will need is a variable intake runner, there has been some talk about it recently, here is one of the posts:
http://forums.maxima.org/showthread....ghlight=intake
In addition, as far as I can remember, the 5th gen one will not simply bolt onto the 4th gens.
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
