Getting a stuck PIN out of a harness connector
I have a situation where there's a stuck PIN in the TCU and the ECM wiring harnesses. I have the TCU harness connector end loosened (the white block on the plastic connector is raised), but I cannot for the life of me figure out how to unlock the wire from the connector so that it will slide out of the back of the connector so I can pull the broken TCU pin out of the wire female end slot.
Is there any technique I am missing here that would apply to the TCU and ECM harness connector to "gracefully" get the wire(s) out?
FYI - This is all that stands between me trying to crank the car and if it doesn't work, I will throw in the towel on getting her running again.
Anybody?
Anybody?
Done it a million times. What you need is a needle to bend the clip and free the pin or terminal connector so you can pull it out. The location of the clip varies depending on the type of connector.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
