Best Head Gasket
Best Head Gasket
Ok here's the deal i have a 96 max that i turbo'd and the engine blew a head gasket...now that i have another engine im goin to put a better head gasket on it and possibly piston rings...and a gasket kit...but I want to know what head gasket would i need to go with...a stock head gasket?? copper?? Im only running 8-10 psi...
new engine and better tune, forget cracking open that compromised engine for only 8-10lbs of boost. you should not be blowing anything on that little boost if your tune is worth a damn.
Bad tune and or components lead to massive heat and engine damage. Some people don't even run widebands most of the time. In my personal opinion egts can be monitored as well to indicate problems because afrs don't always tell the tale. Install another engine, it will be cheaper.
I agree, get another used engine. http://www.motoiq.com/magazine_artic...st-3-days.aspx BTW they ran over 20 psi and made over 600whp on a stock motor.
If you are running the blue, p.m me, I'll give you my email so you can send me your emanage file and I can look at your maps to help you out.
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
