PA FS: 2 Brand New key fob remotes
My remote stopped working so I ordered these.. My remote started working again the next day.. Don't need these anymore..
2 Brand New Nissan Remotes for 96 -99 maxima
FCC id A269ZU078
I programmed one of these just to see what the range is like and it's easily just as far as my stock maxima remote!!
Asking $15 shipped each
or $27 shipped for both..
FCC id A269ZU078
Programming is the same as with a stock maxima remote..
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds.
Your Hazard Lamps will flash if you have performed this step successfully. ( Withdraw key completely from
ignition cylinder each time ) . If this procedure is performed too fast, system will not enter programming
mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push LOCK button on the keyless remote. Your Hazard Lamps should flash. ( Do not press
the button more than one time in the above step). If the button is pressed more than one time, the
programming procedure will not be successful.
5. If there are any remaining remotes (including the old ones), unlock then lock all doors using the driver’s
side power lock/unlock switch and within 5 seconds, push LOCK button on the next remote. Your Hazard
Lamps should flash. Repeat this step for each keyless remote (including any existing keyless remotes).
6. Turn the key to the OFF position, remove keys from the ignition, Open door, Test Remotes
mode.
Just go through the programing posted above. After you insert and remove your key 6 times if your turn signals flash then you have keyless entry. If they don't flash then you probably don't have keyless entry..
litch
123
Jan 4, 2024 07:01 PM
