no turn signals
The turn signal uses fuse #14, 7.5 amps, middle column, 3rd from the bottom.
Do the hazard flashers work? The flasher/blinker unit is used by both the turn signals and the hazard flashers and is something that could go bad. The hazard flashers use a different fuse, though, # 11, left column, top fuse.
If the hazard flashers work, the you are looking at either fuse # 14, or the turn signal switch.
If the hazard flashers do not work, then you are looking at either the flasher unit or the hazard flasher switch.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
