after changing spark plugs, any problems?
Old Jan 15, 2002 | 01:13 PM
Cumalot's Avatar
I just switched back to the normal factory spec NGK spark plugs. I had the one step colder spark plugs in there before because of the SC. Anyway, after I installed them, I started up the car and the car acted really weird. The car was shaking for some reason. Also, it made my exhaust tone sounded really odd, kind of like putt...putt...putt. Maybe it need some time to readjust? I did took off the negative battery cable when I was in the process of swapping the spark plugs out. Should I just disconnect the cable again and leave it overnight so it have some time to reset? Thanks in advance.
Old Jan 15, 2002 | 01:14 PM
Sprint's Avatar
why on Gods green earth would you take off the battery cable to change spark plugs?
Old Jan 15, 2002 | 01:16 PM
deezo's Avatar
To reset the ECU?????
Old Jan 15, 2002 | 01:18 PM
Sprint's Avatar
why would he reset the ECU after changing plugs?
Old Jan 15, 2002 | 01:21 PM
deezo's Avatar
Maybe he thinks it has something to do with his problem (not that I'm saying this should be done when changing plugs).
Old Jan 15, 2002 | 01:25 PM
Sprint's Avatar
oh..
Old Jan 15, 2002 | 01:27 PM
deezo's Avatar
oh..
You don't know me better than that???
Old Jan 15, 2002 | 01:30 PM
Sprint's Avatar
no i said Oh to your interpetation of his thoughts..
Old Jan 15, 2002 | 01:32 PM
deezo's Avatar
I was talking about.............oh forget it.
Old Jan 15, 2002 | 01:34 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Did you reconnect all your coilpacks? Sounds like you missed one (some).
Old Jan 15, 2002 | 01:36 PM
Sprint's Avatar
muhahhaha.. thats the funniest **** i have read on the board all day
Old Jan 15, 2002 | 01:38 PM
Y2KevSE's Avatar
Old Jan 15, 2002 | 01:49 PM
MardiGrasMax's Avatar
Yeppers!
Or the coil pack it not touching the plug good?
Or the plugs are not torqued properly and leaking?
Old Jan 15, 2002 | 04:39 PM
Cumalot's Avatar
I think I did everything right. Could overtighening them be a problem? I'll recheck them again now.
Sprint: thanks for the help.
Old Jan 15, 2002 | 04:42 PM
I dount over tightening them would do this unless you cracked the heads?
Old Jan 15, 2002 | 05:21 PM
Cumalot's Avatar
Well, I found the problem. The connector on the rear driver side spark plug wasn't plugged in all the way. I heard a click so I thought it was in. The problem was one of the metal notches in the connector was bent. I took a flat head screwdriver and straighten the bent notch. After that, the connector went in fine. Problem fixed. So, I didn't do anything wrong, just didn't realize the notch was bent on one of the connectors. You guys have to give me some credit, I'm not that dumb.
Old Jan 15, 2002 | 06:01 PM
Sprint's Avatar
I'm not that dumb.
Actually they were right.. the coil pack wasn't connected
Old Jan 15, 2002 | 10:37 PM
Y2KevSE's Avatar
Go unplug two coils and find some Hondas to race.
Old Jan 16, 2002 | 08:28 AM
Ben4bamaMax's Avatar
are Bosch Platinums o.k. to use?
they are 2.19 vs. $12 each for NGK.
Old Jan 17, 2002 | 05:45 AM
Sprint's Avatar
Re: are Bosch Platinums o.k. to use?
no Bosch plugs suck
Old Jan 17, 2002 | 05:51 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
A) Those plugs aren't $12/each. Maybe $60 AFTER shipping....but that would require reading the 4th gen maintenance sticky in the 4th gen forum or looking at the sticky FAQ links at the top of this forum to see what dealers offer discounted parts.
B) Bosch Platinums do indeed have issues.....I've had many problems with them personally.
C) NGK will allow the VQ to perform as Nissan intended. Other plugs simply will not, despite what others may perceive.
D) If you can't afford maintenance parts, don't buy Maximas.....go get a nice Corolla or Civic.
MAXSE5SPD
Sep 17, 2022 04:00 AM
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
Johnny9595
Sep 3, 2015 05:18 AM
Turbobink
Aug 15, 2015 07:20 AM
