Air Intake Hose Problem - Urgent!
Hello dudes and dudettes,
While prepping my car for the smog in October I discovered that the air intake hose leading from the vacuum line box, as i like to call it, to the throttle body is actually ripped.
This could explain why I have pending codes for the knock sensor and for the swirl control valve.
I have attached pictures of where it is ripped.
The question is, can I replace it with what appears to be a 3" to 2.5/2.75 adapter or does it have to be stock? Thanks.
3" will work fine for both sides once tightened down. Real problem will be ensuring its long enough. You could also got to the junk yard and get an pen unit for probably $5. I always have a couple of these laying around.
I've got a '00 Infiniti and mine is hard as a rock. I've searched and all aftermarket ones say they will fit up to '99. No one appears to make one for a '00+. Guess I do have to go to the dealer and pay $50.
If that is definitely the route you intend to go, then call Wayne or Ray at Tricity Nissan. Get their number here www.nissanpartsasap.com and tell them you're from the .org forums.
MAXSE5SPD
Sep 17, 2022 04:00 AM
vingodine
45
May 21, 2016 12:46 PM
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
