maxima dash/interior lights pulsate
Old Aug 19, 2013 | 05:07 PM
cash94's Avatar
hi,
I have a 2002 maxima with 155k. About a few months ago, my alternator went. So I purchased a reman from advanced. It went in without any problems. Since then, I notice randomly and intermitting, that my gauge cluster and dome lights pulsate. It seems the more load I give it for example; hit the brakes, turn on the dome lights. seems to aggrevate the pulsating. Also when the alternator went, it happened on the way to work, it drove fine, no battery lights or anything. then when I arrived at work and put it in reverse to back in, there was no throttle response, and the dash "idiot lights" came on and when I shut it off the battery was dead. What should I check? thanks in advance
Old Aug 19, 2013 | 05:55 PM
Amerikaner83's Avatar
Clean your grounds, but I'm betting your reman alternator is on its way out
Old Aug 20, 2013 | 12:09 AM
DennisMik's Avatar
I'll second the alternator is going to take a dump on you. If you want, have a voltmeter with you and when the lights pulse, measure the voltage, it should be steady and not fluctuate. You could also try setting the meter to AC volts. It should be real close to zero on the 2 volt scale.
Old Aug 20, 2013 | 06:13 AM
TriniSpeC's Avatar
Third on the alternator going out. If it was your grounds the battery wouldn't have charged ever. Best bet is a rebuilt or OEM alternator
Old Aug 20, 2013 | 05:09 PM
cash94's Avatar
Yeah, im leaning towards a alternator also. I guess Ill have to remove it and have it tested, at least all the bolts are freshly loosened. Should come out fairly quick
EuroDriver
Sep 14, 2015 06:08 PM
Samedi
Aug 13, 2015 04:05 PM
MikesChevelle
Aug 6, 2015 11:36 AM
kjm900r
Aug 5, 2015 07:14 AM
yat70458
Aug 3, 2015 01:16 PM
